Anyone milled their F20c cyl head and thinner headgasket ?
If so how much did you mill, 15 to 20 thousandths of an inch ? did you try using with a stock two layer headergasket (taking out middle layer) ? was there a noticeable difference in performance from bump in compression or just not worth it ?
Greg
Greg
Sorry for bumping a 10 year old thread but I'm curious since I just dropped off my head and I'm having it milled .020 I'll be using the stock head gasket in it's original form though
Billman recently replied to another thread and recommended strongly not to mill head for compression. Only do it if required if head warped and its required.
Its not worth the compromises incurred.
I'm already running e85 and have been for 2 years now without any issues. I stopped by the machine shop today and talked to the main machinist . He told me it really isn't worth it to mill the head anyways that I would see maybe 1-2hp and that's about it. Plus if anything were to happen in the future there wouldn't be much materiel left to work wth . So I opted to leave it writhin stock specs if possible . Thank you for your help guys . Billman your advice is always a pleasure .
any input my cylinder head will be miling 0.3mm is ther a chancw to use Oem head gasket and without affecting the timing
Why are you milling the head?
Unless the engine was over heated, it is not necessary. Doing so will only skew the chain geometry and cut the chain and sprocket life drastically.
Car overheated and engine idle like a wrx and when cylinder head take off the gasket is warp and the head brought to machine shop to evaluate the warpage and they say to make it perfectly flat again shave at least 0.3mm
whats the best option for this is there no chance to use the cylinder head?
