Anyone use Nippon FRM pistons?
#51
And are magnetic to prove ^^
#52
then if a rebuild x1 overbore only.do it all again=$.
so 8x the cost.<100k>miles.
#53
They got a set of used pistons still in good shape on ebay last I checked.
#54
And just FYI, a set of oem pistons/rings alone will run you over $1100...then good luck finding someone that can bore/hone that FRM block without fking it up.
#55
ebay example
#56
https://www.ebay.com/itm/Honda-S2000-S2k-Ap1-2000-2003-Rods-And-Pistons-OEM-Used-stock-2001-2002-00-01-S/292858149250?_trkparms=aid%3D222007%26algo%3DSIM.M BE%26ao%3D1%26asc%3D20180213162448%26meid%3Dd36072 e900064ce59b7f64ee6c7e2d64%26pid%3D100930%26rk%3D1 %26rkt%3D8%26sd%3D292868964516%26itm%3D29285814925 0&_trksid=p2056116.c100930.m5375
I was talking about these. In any case light scuffing on the skirts is normal.
#57
Sure would be nice, if those sellers would have some mic data (esp ring land wear, ring gap) on those specific pistons.
#58
On a side note, if any of you guys have a desire for used oem pistons I probably have 3 or 4 sets...along with anything else you might need for a f20 or f22
#59
Hello everyone,
I apologize for the delay in responding. The original plan to use the Nippon pistons in my F22 has been abandoned because I managed to blow my other s2000 (money shift).... that is priority now. The new plan is to run these pistons in an F20 instead using the 87.25mm bore block. A few things I'd like to add:
-The Nippon pistons are NOT iron plated like the factory pistons. I have applied abradable powder coating from Line2Line to minimize piston slap and see how that does.
-The 2nd ring gap is smaller than OEM, which may result in some top ring flutter at high RPMs. For the sake of experimentation, I will not change the gap and run a dyno test afterwards. The current gap on the provided 2nd rings are for a K24.
I'm currently rebuilding the engine and will have news soon.
#60
Hello everyone,
