bleeding clutch problems
After I bleed my clutch, I hear a weird noise right after i step on my clutch and release it.
How did you bleed the clutch? Did you let the reservoir run dry during the process.
Did you mess with your clutch slave cylinder? I had a car in for CDV removal and it had the fork almost falling out. It made scary grinding noises after we replaced the clutch fluid. Had to pop the rubber and re-insert the fork firmly.
i did it on this DIY.
(https://www.s2ki.com/forums/index.php?showtopic=118878) I had some bubble coming out, but i took out the air already. i dont think i mess with the clutch slave cylinder |
