Originally Posted by zeroptzero
(Post 24458407)
peace of mind test - swap in an oem cat, if the smoke goes away you are all good. If the smoke continues you have a mechanical issue. If it goes away with an oem cat then go back to your test pipe and no need to worry about it any further, enjoy the drive.
^ I couldn't tell how much oil consumption he was referring to, other than saying it consumes enough oil for normal driving ? It might help to know what oil consumption level the motor is experiencing though, in quarts / 1000 miles.
(Post 24458441)
Finally got the car out this past weekend.
Had gone back to 10w30 oil in it..... Still getting smoke, and its back to blue. Only other thing left to try is the OEM cat instead of the Berk HiFlow cat. |
You have to change the valve guides.It's the last you should do to make sure the head is ok.The misfires you saw back then is a common symptom of worn valve guides/valves.You'll be lucky if the problem is the head.Otherwise you are messing with the cylinders/pistons/rings which is difficult to repair and very expensive.Hope that's the cylinderhead.
Originally Posted by nipponS2000
(Post 24458753)
To the OP, are you sure the guides were replaced and not just the seals? Are you sure the machinist actually did the work? I had a machinist try to convince me once to knurl the guides instead of replacing them because it was easier for him. Hope you don't mind me challenging you on this, but as I said above, the symptoms fit so well, especially for a higher mileage head, I wanted to be double check that you don't think they were changed when they were not. |
Originally Posted by DanielB
(Post 24458807)
The OP said he changed them. I still think they are suspect as the symptoms fit worn valve guides.
my information was in regard to grey/whitish smoke, if you have blue smoke it is oil getting into the combustion chamber somehow. If it smells like burning oil then it likely is.
Originally Posted by s2000Junky
(Post 24458466)
The Original poster said 1Q in 3k miles. But my response was in regard to the most current poster a few back "Nippon" who stated 1.5Q in 3k miles and did a full valve guide/seal replacement with still no change in consumption reduction.
I recently bought my first old school Honda that does not burn oil, it is a 2000 Acura GS-R with 190,000 kms on it, it does not burn a drop much to my surprise and I've been putting it through its paces. My 10 previous Hondas all burned some oil. My newest Hondas - 2016 Civic turbo and 2017 Hr-v don't burn any oil yet, so far so good. |
(Post 24458807)
