Brake Piston
Old Dec 31, 2001 | 12:21 PM
pll's Avatar
pll
I'm trying to install my Panther Plus pads and I can't get the caliper to fit over the new pads. It looks like the brake piston is in the way by about 2 to 3 mm. How do I retract the piston? I'm doing the front pads right now. Thanks!
Old Dec 31, 2001 | 12:26 PM
sgr's Avatar
sgr
For the fronts, you can just use a C-clamp to compress the calipers out of the way. Alternatively, a tool specifically made for that purpose can be bought at any carparts store for cheap. For the backs, you have to screw the piston into the caliper. I layed a small screwdriver into the grooves on the piston for leverage. Again, a cheap, relatively generic tool can be bought to make the task a little easier.
Good luck.
Old Dec 31, 2001 | 12:27 PM
pll's Avatar
pll
Thanks. I'll give it a try.
Old Dec 31, 2001 | 12:35 PM
gregstevens's Avatar
Banned
Yea, use a c-clamp on the fronts and put an old pad across the ridge of the piston and then use the clamp to squeeze the piston back in.
You have a couple of options for the rears. There are a variety of tools for this...one is a like a little cube which has a different "tooth" pattern on each side...this tool is used with a socket driver. Works pretty well, but don't use it with an extension...it's harder to gain leverage with an extension, trust me...
But for the rears, I use an ordinary shelf bracket. It's rather heavy duty and is just a little less wide than the cross-hatch pattern on the rear piston...so it fits well into the piston. And the 90 degree angle of the bracket helps when turning the piston back in...
Good luck!
Old Dec 31, 2001 | 03:10 PM
pll's Avatar
pll
Thanks guys! I installed the brake pads and bled the fluid.
I used a funky tool I found in the garage to clamp the front pistons. It's like an oversized plier. I'm not sure what it's used for but it worked.
For the rears, I just used the shaft of a screwdriver to turn the piston. I think I'll invest in a tool to do it in the future.
Old Jan 2, 2002 | 11:03 AM
CarbotechAndie's Avatar
[QUOTE]Originally posted by gilcwong
[B]Thanks guys!
Old Jan 2, 2002 | 02:02 PM
SilverSurfer's Avatar
[B]Thanks guys!
Old Jan 2, 2002 | 07:49 PM
RT's Avatar
RT
[QUOTE]Originally posted by SilverSurfer
[B]
I use a bare 3/8 in ratchet.
AZS2KDancer
Jul 10, 2016 09:23 PM
SDueces
Mar 2, 2014 09:24 PM
PierreC
Apr 11, 2012 09:20 AM
ianl
Mar 8, 2006 02:44 PM
jah
Dec 16, 2005 06:20 AM
