Brakes locked up after suspension and Exhaust install
Over the last week I installed a set of Ohlins shocks, and a new exhaust and test pipe, along with some new wheels and tires. I took the car down off the stands and noticed when I went to back out of the garage, the car wouldn't move without gunning the gas. I got out and checked and there was brake pad shredded all over the wheels. Scratching my head as to what it could be that would cause this. There are no dash lights, and I reset the ECU before taking it off the stands, but left it on ramps while restarting the car. The brakes worked fine before I put the car up on stands almost a week ago.
Year is 2000, and pretty sure its front brakes (due to shredded brake material), I have to check the rears to be absolutely sure. The front wheels spun freely before I lowered the car back to the ground. I will check as soon as I can.
If your brakes are binding you should check to see if your caliper pins are moving freely. They can bind due to corrosion. It could be a coincidence that the symptoms show up now. If they haven't been re-greased lately, you should get this done. It's a pretty simple DIY job unless you have a pin that's rusted up.
So your wheels are hitting your calipers?
That sucks!!!
That sucks!!!
