S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Under The Hood (https://www.s2ki.com/forums/s2000-under-hood-22/)
-   -   Broken Lug Stud (https://www.s2ki.com/forums/s2000-under-hood-22/broken-lug-stud-946748/)
tdcs2k Apr 21, 2012 07:57 AM
Broken Lug Stud
I noticed some strange sounds and a wheel balance vibration on the front left wheel and discovered 2/5 lug studs had broken. Is it necassary to remove the hub to replace lug studs, or can I do it with the hub on the car?
Billman250 Apr 21, 2012 08:36 AM
Hub has to be completely removed front or rear. There is zreo clearance. Some cars can be notched to make room, not this one.
tdcs2k Apr 22, 2012 08:21 AM
Ok. I wanted to try and do it myself, but after looking into it I decided it looked like more trouble than I wanted to deal with. I just drop it off at the local shop I use. I'm guessing $300 - $400 to have the hub pulled and the lug studs & bearing replaced. Does that sound about right?
estooki Apr 22, 2012 09:53 AM
damn thats a lot
i broke a stud before, not really that hard to replace it
local shop around me charges 60 to replace the studs, stud and lug nut included with labor
© 2026 MH Sub I, LLC dba Internet Brands
