"Broken right camshaft sensor"
Old 04-15-2013, 06:16 AM
IdiotCircusBoy's Avatar
Default "Broken right camshaft sensor"
Hey there folks, I went to the dealership on Sunday to get a valve adjustment done (it was practically free) and the technician wrote down that I have a "broken right camshaft sensor." I'm guessing he means that I have a broken TDC sensor, but I didn't get the chance to ask as I was being rushed out of the door.
Would the TDC sensor be considered a "camshaft" sensor?
Old 04-15-2013, 06:51 AM
zeroptzero's Avatar
Received 3,361 Likes on 2,444 Posts
On 2000-2005 there are two Top Dead Cam sensors in the valvecover, they detect the position of the cams - one for each.
Did they fix the broken sensor ?, or is it just a broken clip on the sensor which they simply fastened ?. It would be good to get more info on the issue. I would assume it wasn't a total failure of the sensor or you would have other issues.
Old 04-15-2013, 07:04 AM
Originally Posted by JFUSION
On 2000-2005 there are two Top Dead Cam sensors in the valvecover, they detect when the position of the cams - one for each.
I took a look at both TDC sensors and they both look fine, the clips are not broken either and I've yet to see a CEL turn on or notice any effect whatsoever, which is why I'm so confused. I also do not believe that these were replaced at all.
MB
02-10-2017 02:31 AM
blueducatikidd
04-21-2011 06:11 PM
AROD
05-28-2007 12:16 PM
Quick Reply: "Broken right camshaft sensor"
