Camshaft position
Camshaft position
How can you find out what exact position the cams need to be in w/o removing the head(assuming you installed them in what you thought was the same position you removed them from only to find out you have no compression)? Asking for a friend...
The cams are marked in and ex, that's step 1, then it's just a matter of aligning the marks, crank pulley and timing case, two notches on the camwheel level with the head and the marks on the camshaft gears facing each other.
Intake and exhaust lobes should be pointing at 2 and 10 on cylinder 1 if you lined up everything correctly.
