car acting up. idle and at speed
Hello,
My names Ryan. Lately I've been having some probs with my S, I was hoping I could get some insight from anyone who might have been down this road. I've been searching for the last 2 weeks and I'm tired of dancing around with this prob.
First off I haven't had any CELs so I haven't been able to scan for codes. My idle is fine at times and low/rough at other times. Yesterday it kept stalling, I had to give it gas to keep the rev up at stop signs and what not.
Underload it jumps in low gears like a newb learning to drive stick. Around 3-6k at mild accel or steady cruising it'll hiccup and hesitate sometimes bog for a bit. It feels like the throttle closes a bit and reopens to where it should be.
I've swapped out air filter, MAP sensor, spark plugs, TPS. My only engine mod is a t1r exhaust, SoS TB and a comptech air filter. I just passed my smog test perfectly too which makes me think its not the O2 sensor.
Sorry for the novel, if you can point me in the right direction I'd be soo apprecitive.
Thanks,
Ryan
Thanks,
Ryan
Update:
Just got a CEL, 2 codes. P1129 (manifold pressure higher then expected,MAP) and P1399(misfire)
A lot of posts with people having the same prob but no posts on how people fix it.
Any siggestions?
UPDATE:
it was one of the battery cables(not on the battery) that was loose tripping out the ecu.
Any siggestions?
UPDATE:
Although, I'm puzzled by the P1129 code...that is normally a MAP sensor issue.
Also...I'm curious...above you say you replaced the TPS (throttle position sensor). On our car it is not possible to replace the TPS with OEM unless you replace the throttle body too. And I'm not aware of anyone who makes an aftermarket TPS for our car yet. Did you replace it yourself? If so, I would love to know whose TPS you were able to use. And if a mechanic did it for you...you may have been jipped...which would also make me suspect that the MAP wasn't replaced either, which is why you are getting the P1129 code.
The TB was a science of speed TB it came with a TPS. The map sensor I replaced my self.
Its possable that my plugs are not gapped properly, it seemed the prob esclated a couple days after swappin them. Any ideas on that?
I've been cleaning all my sensors how do you test the coils?
Thanks,
Ryan
Thanks,
Ryan
If you bought oem plugs, they should be gapped correctly out of the box...but it doesn't hurt to double check.
The owner whose issue lead to a bad coil "tested" by waiting until the coil completely died and the car was running on 3 cyl. He started the car from cold and felt the exhaust header primaries...the one that stayed cold was the one with the bad coil.
Not sure there is another way to easily test coil packs.
Wow, it just so happens that I felt these same exact symptoms a couple of weeks ago and again today. I only have 57K on my odometer, so im hoping its just my plugs.
How long did it take for the CEL to kick on from when you first started experiencing the bogs/ hiccups?
Originally Posted by negcamber,Dec 22 2007, 09:25 AM
<snip> I'm not aware of anyone who makes an aftermarket TPS for our car yet. <snip>
http://www.omnipowerusa.com/product.asp?P_ID=137
It took a few months before I got a CEL. I don't daily drive it tho, so I think it took longer because of that. It started with a hiccup every so often to now it does it all the time.
Start by checking your map its cheap.
On the omni power TPS, I belive they would need to be calibrated to the S2K specs. Also the stock sensor will need to be drilled out and re tapped for the new sensor. It has tamper proof screws.
