car dies after iacv cleaning
Old 12-30-2017, 10:34 AM
fuzzysig's Avatar
Default car dies after iacv cleaning
had the car for few weeks now
the idle was dropping after start and at traffic lights
I cleaned up the grounds and battery terminals checked few other things
today cleaned iacv and now the car doesn't just dip idle it actually dies if I rev the motor in neutral
I did the ecu reset and learn idle and nothing changed
still shuts down
is there anything else that could be wrong ?
also weird thing was when I started after resetting the ecu I heard ticking sound fro about 5 seconds and it slowly went away.
never heard it before
Old 12-30-2017, 10:41 AM
Thomas Guide's Avatar
https://www.s2ki.com/forums/s2000-un...neric-1180453/
Old 12-30-2017, 01:04 PM
HarryD's Avatar
When you are doing your ECU reset, are you letting the car figure itself out, or are you blipping the throttle when it looks like it's going to die?
Also, when you cleaned the IACV, did you do it the right way, insofar as the torx bolts and cleaning and spinning the internal shaft until it spins freely?
Old 12-30-2017, 03:45 PM
fuzzysig's Avatar
no i usually spray small amounts of carb cleaner into the iacv intake as the car is warming up. did it to every b series since they all have same issue and it worked every time
i feel like theres another issue that is causing it with this car
Old 12-30-2017, 07:53 PM
fuzzysig's Avatar
map and tps connectors are good
i checked both
Old 12-30-2017, 11:15 PM
Car Analogy's Avatar
Received 1,304 Likes on 987 Posts
You have to clean the iacv per the billman instructions with this car. Look for diy, follow that.
Old 12-31-2017, 05:59 AM
If I may recommend again the link I provided earlier as this was just brought up the other day. I put together a very comprehensive post detailing my issues and the steps taken to resolve my idle issues. The post includes multiple DIY videos and 2 detailed threads explaining idling issues with an incredible amount of information, what to look for and how to resolve them, take 30 minutes and read everything there, and watch those videos, it will really help you come up with a plan and cross items off with a process of elimination. If you don't follow the instructions exactly to clean the IACV or other components then you're pretty much just not doing it right to fix the problem. Good luck!
Old 12-31-2017, 10:31 AM
fuzzysig's Avatar
thanks ill try taking it apart. i didnt know you can remove the motor assembly on this one.
Old 01-03-2018, 12:30 PM
fuzzysig's Avatar
did that
clean the valve greased the bearing after
checked map sensor and tps connectors
cleaned the tb passages
new spark plugs
checked all the grounds
and relearned idle again
still doing it.
drops very low after start and whwn i bump the throttle at idle
doesnt do it when driving
Old 01-03-2018, 04:09 PM
HarryD's Avatar
I already asked:
"When you are doing your ECU reset, are you letting the car figure itself out, or are you blipping the throttle when it looks like it's going to die?"
I asked because the car needs to figure itself out for a few minutes after an ECU reset -- do not touch the throttle when it's about to die after the reset.
Quick Reply: car dies after iacv cleaning
