Car stalls when I take my foot off the gas!
Old 08-30-2010, 04:29 PM
vbb
vbb's Avatar
Originally Posted by jamest16748500,Aug 30 2010, 05:49 PM
also check your ivac and clean it
Ivac?
Also, is there a way to check the tps to see if that's the issue without replacing the entire throttle body?
Old 08-30-2010, 05:17 PM
Not Sure's Avatar
Originally Posted by vbb,Aug 30 2010, 04:29 PM
Ivac?
IAC motor - Cleaning it sometimes fixes your problem.
THere's a lot of old threads about this:
https://www.s2ki.com/forums/index.ph...ic=386868&st=0
Old 08-31-2010, 06:54 AM
jimnasty23's Avatar
Ivac?
I went to honda because mine got real bad, they hooked it up to there computer and told me its reading half of what the tps sensor is suppost to be reading( i forgot the numbers, i think its 5.0 ohms? I could be wrong. but mine was half of that), which usually means your tps is going bad(says honda). Now there is a thread on how to test the it, and also a thread on how to replace it without replacing the entire TB(i personally dont trust the diy thread on replacing it, but alot of ppl have done it and have had great success).
Old 10-30-2011, 08:06 AM
americansailor89's Avatar
i am having this same issue right now. only i just installed a skunk2 70mm throttle body. the car ran just perfect before, and now something is wrong. my tps volts is at .5 at adle and WOT is supposed to be 5.0v but mine is at 9.7. idle is normal volts, WOT is almost double. not sure why. and not sure if this would having any issue with the car dying. please help
Old 10-30-2011, 03:01 PM
2003AP1's Avatar
Clean your IAC and tb if that dont fix it you need a tps more then likely like stated above.
AdN
09-09-2013 03:27 AM
Devinb
12-23-2011 07:21 PM
LoganX4
03-07-2009 03:38 PM
S2K Type R
09-03-2008 04:46 PM
JspecVtec
11-14-2007 06:11 PM
Quick Reply: Car stalls when I take my foot off the gas!
