Check Engine Light w/ VSA light
Old Jul 15, 2012 | 08:13 AM
GoodEyeSniper's Avatar
Default Check Engine Light w/ VSA light
Hey everybody,
I was driving home after being stuck in traffic and out of the blue my "check engine" and "vsa!" warning lights came on together. Afterwards, the car started stuttering everytime I let off the gas. It felt like a bunch of random jerking. I was able to make it home without any other issues, but it was an uncmofortable ride. A few days prior to this incident, I had changed my rear brakes. Does anyone know what may be the cause of this or can anyone give me any info on what it may be? I have her parked for now and I'm waiting for my brother to bring over the code reader device.. Any information would be appreciated. Thanks .
Old Jul 17, 2012 | 11:00 AM
Eviljokersti's Avatar
what year is you S? I have an 06 and have the same issue, the problem is the TPs sensor. After doiing some research i found it seems to be a common issue with 06/07 DBW systems. you are gonna have to replace the APP sensor. This is the part you will need.
http://www.rockauto.com/catalog/x,ca...,parttype,5061
but before you drop the money on it. I heard of a few ways that might fix the issue. (1) check the throttle cable tension, if its loose tighten it back up, (2) clean the sensore pins try these then reset the codes. If they come back then you have to buy the part.
Old Jul 17, 2012 | 11:06 AM
Its 2007 . Thanks for your help. I will do that now.. by any chance do u know if it may be related to me doing my brakes?
Old Jul 17, 2012 | 11:17 AM
I wouldnt think so
Old Jul 22, 2012 | 04:47 PM
gsr_crx1989's Avatar
i just had this problem and i had the app sensor replaced and it runs good now....if you do end up replacing it
let me know how it rides after because after replacing my app sensor i feel i have less power but idk if its
just me thanks
Old Jul 23, 2012 | 12:01 AM
just me thanks
I recently took her to Honda and unfortunately the part was back ordered so I won't get it til the end of this month. It cost $175 for the part alone and the labor will be around $100. It doesn't look that hard to replace, but I don't want to try and mess anything up so I'll let honda deal with it. I'll keep an update and tell you how everything goes.
Old Jul 23, 2012 | 09:28 AM
just me thanks
Go to Rockauto.com they will ship you the part in 3 days. The install is easier than changing your oil. all you need it a 10mm socket with extension, and a 12mm open ended wrench.
Old Jul 23, 2012 | 09:29 AM
Old Aug 12, 2012 | 08:30 AM
So, I've finally had the APP sensor replace. I've been driving her for about a week and have not had any issues with it. As far as how she rides.. she's definitely smoother. I can't really tell if it's loss any power, but I have notice that it doesn't have much of a pull that I would want it to have when I accelerate. I can't remember if it was like that before, but maybe i'll invest in an intake or something..
Old Aug 13, 2012 | 06:55 AM
Croc's Avatar
maybe some tuning needs to be done by HDS?
