clunk/popping noise from steering
Old 09-27-2010, 06:53 PM
OneSilverS2k's Avatar
Check your sway bar end links.
Old 09-29-2010, 06:28 AM
Groove_D's Avatar
Sway bar links are ok. It's not suspension type noise. It sounds like a body clunk noise.
Old 09-29-2010, 02:42 PM
SgtB's Avatar
Check the ball-joints, and all the control arm pivots. The bushings have a metal sleeve in them that likes to stick to the bolt. Enough cycles of break/seize will wear the insert out. Make sure you subframe bolts are tight too!
Old 09-29-2010, 03:28 PM
spaap1sup's Avatar
I have the same problem. Its the rack bushing for me
Old 10-01-2010, 10:42 AM
Groove_D's Avatar
Hey man, i actually saw it today too. I was able to duplicate the noise while turning steering wheel rapidly left and right. I saw the rack bushings move too much. I re tightened the bolts but obviously looks like the bushings are worn.
What did you end up doing? Replaced the bushings?
Old 10-04-2010, 11:19 AM
Groove_D's Avatar
Bump
Old 10-17-2010, 07:08 AM
Groove_D's Avatar
Anyone else?
Old 11-11-2012, 03:05 PM
Cosworth's Avatar
Back from the dead... does anyone know the solution to this problem? I think mine is having the same symptom.
Old 07-03-2013, 01:50 PM
Suzuka_BlueS2K's Avatar
Same issue here where does one begin?
Old 07-05-2013, 07:48 AM
TonysMI4's Avatar
Same issue here also
Quick Reply: clunk/popping noise from steering
