Clutch failure (anyone had similar experience?) and recommendations for replacement
After dealing with rusty bolts I got clutch parts out of the car. I found out that infamous upper starter motor bolt was missing.
I think this isn't oem Honda clutch disc. Can anyone confirm?
Flywheel has some wear too what you can feel with finger.
OP, thanks for posting up the source of the problem! That clutch failure looks pretty bad.
No I didn't find any marking of whose product the clutch disc is. Still waiting one delivery and then I can get to work.
These parts I chosen:
OEM clutch disc, pressure plate and release bearing from local Honda dealer 445€
ACT prolite flywheel from FRSport 420€ with tax
Lot of new OEM bolts and small bits from Amayama.com
Yes I did order new release bearing guide.
I have SKF urea grease what should be good for clutch release bearing: LGHP 2 SKF high performance, high temperature bearing grease
New parts are now in and car is running nicely. Clutch feels super smooth
I only notice lighter flywheel when changing gear. Rpm:s drop quicker.
Few pics: https://www.s2ki.com/forums/automoti.../#post24488424
Thanks for help!
Thanks for help!
