Clutch Master and Slave Cylinder replacement
Hello everyone, I'm replacing both of these parts this weekend and haven't found a DIY on both being done together. Question is, should I flush the whole system and leave it dry before replacing both? Or will this affect something in a certain way... Thanks
i literally just replaced my clutch master 2 weeks ago. I did not bench bleed nothin'. I mean i tried but then all the fluid just fell out so i put it in dry. The FSM did not make mention of bench bleeding. Check out the youtube video which outlines the process.
Once all the parts are reinstalled, fill the CMC with dot3 or 4, open the bleed valve with a little tube attached, and wait till it drains without air bubbles. Because i left the fluid in the hard line- as i didn't need to replace my slave cyl- it drained thru in minutes- like less then 2 minutes so keep a real close eye that you don't reintroduce air into the system.
good luck
darcy
good luck
darcy
Old motorcycle trick, unbolt the slave and make sure the bleeder points at Jesus (perpendicular to the ground) gravity bleed it and you are guaranteed to get all the air out.
Any recommendations on a particular brand of CMC?
There are two from BLOX racing, one that is to OEM spec and then a competition one. I'm eyeing the competition one with the assumption that it may be more durable for daily driving and it has a shorter pedal travel.
Keep the fluid clean (turkey-baste) it moving forward for longevity after the install.
OEM is definitely the most pain free way to go.
