clutch pedal not coming back up
Old 02-19-2011, 11:47 AM
03S2's Avatar
Default clutch pedal not coming back up
well i started out with a differant problem at first. originally i was having to press the clutch pedal further and further down to get the car in gear, so i thought slave cylinder. about an hour ago before i replaced my slave cylinder i noticed my clutch pedal would'nt come back up on its own. i went ahead and replaced the slave cylinder and i am still having the problem with clutch pedal not coming back up. please help i am completly lost
Old 02-19-2011, 01:10 PM
BowlofRice's Avatar
Did you bench bleed the slave cylinder? How did the clutch fluid look? Did you flush that out as well?
Old 02-19-2011, 02:41 PM
03S2's Avatar
how do you properly bleed the slave cylinder?
Old 02-19-2011, 02:46 PM
s2k dre's Avatar
Since its installed already just keep bleeding with the pumping method. It will work since u replaced the master and the slave.
Old 02-19-2011, 02:53 PM
03S2's Avatar
does this usually take awhile? i have had my wife out pumping the clutch and holding it down while i open the bleed for the little bit of pressure that has built to escape(AIR). But we have been doing that for about 15 minutes. do i just need to continue doing the same thing? oh and should i eventually feel a differance in the clutch?
Old 02-19-2011, 02:56 PM
s2k dre's Avatar
It should get full pressure in a few min. Something else might be wrong. Did u check to see if ur master is leaking near the clutch pedal?
Old 02-19-2011, 03:05 PM
03S2's Avatar
ill go check behind the clutch pedal. would it really be noticable, i mean would fluid be visible? the master cylinder reservoir is still full, i dont know if that means anything. thanks for everyone, your being very helpful.
Old 02-19-2011, 03:17 PM
03S2's Avatar
ok, theres no leeking that i can see behind the clutch pedal. i contiued to bleed and the pedal contiues to basically just fall to the floor. this is frustrating lol.
Old 02-19-2011, 07:38 PM
RedY2KS2k's Avatar
Originally Posted by BowlofRice,Feb 19 2011, 05:10 PM
Did you bench bleed the slave cylinder?...
Old 02-20-2011, 10:15 AM
03S2's Avatar
how do you bench bleed the slave cylinder?
Quick Reply: clutch pedal not coming back up
