Clutch Rod Play
#21
isnt there a picture of this and how to adjust the rod somewhere on here? if someone manages to find it, could you throw it in here to have all of the info together?
#22
Originally Posted by Great To Be Alive,Feb 19 2011, 12:30 AM
That's why I wanted to clarify. Really important to read Billman's post on the two types of play that you feel and can see when looking at the assembly. This was the light bulb moment for me. Otherwise you can easily screw up your clutch.
#23
Do this adjustment at your own risk!
https://www.s2ki.com/forums/index.php?showt...0&#entry5234269
#25
Originally Posted by fastD,Feb 20 2011, 10:59 PM
I actually went too far and found that I could cause my clutch to slip. I have readjusted for a smaller amount of freeplay and will try that out tomorrow.
I compared my clutch pedal measurements with the shop manual tonight and it says my pedal should be 7.74 inches from the floor, I think mind is just over 6 inches, and it is already higher than the brake pedal, I'd hate to see it up at 7.74 inches. I think as long as the stroke distance is within spec I'll leave it as it is, I don't want to mess with it too much and I don't want my clutch pedal up too high if I can get away with it.
#26
thanks great to be alive, that is the exact thread i was looking for! i read in that thread the first time some of the general concerns/issues people had so i knew to proceed with caution. i have a little 2nd gear grind no matter how careful i am so i know i need to tighten it up a bit.
