Clutch Rod Play
#64
Iit was my mis-reading through the posts that free play in the pedal would be eliminated, and thus was adjusting the rod past the initial point of resistance to limit the free play in the pedal, which I now know is incorrect
Mine is now exactly like in the video with the rod at the point of resistance with about 1/4" of free play in the pedal.
My write up would be, as from the video:
Loosen the 12 mm nut on the clutch master cylinder rod.
Gradually turn the rod using two fingers in a clockwise direction until hitting a point of resistance.
Once resistance is felt, tighten the 12 mm nut.
The clutch master cylinder rod free play has now been eliminated and the clutch pedal free play should now be no more than 1/2".
