compression?
long story short i ran into some oil starvation and spun a rod bearing. just went to do a compression test to see the shape of the rings and found 208-220 roughly on all cyl. ive searched and found different things for what it should be. ive heard 240, 230, all the way down to 180 which i know has to be wrong. anyone got any input? f20c btw.
altitude makes a difference in those numbers you were researching. it seems fine to me but what is your altitude?
Originally Posted by Andersonracing
(Post 22414639)
as long as the cylinders are consistent between the 4 of them you are good, dont stress the ultimate number as there is variation due to technique and gauge. I think you are in the ballpark of being decent. Maximum variation between any side by side cylinder is approx. 28 psi. , so your engine wouldnt exceed that number from what you have listed. I don't think your cylinders were scuffed when you experienced the oil starvation, if they were it would be very obvious.
| All times are GMT -8. The time now is 04:53 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
