Compression Questions
Hi All --
I'm very intersted in increasing the compression of the F20C from 11.1:1 to something around 12-12.5:1.
I was wondering what would I need in terms of parts to do this and maintain a certain level of reliability in the car?
Thanks in advance!
Thanks in advance!
I would suggest that you look into the type of gas required for 12:1 compression and if the pistons and walls can handle that particular racing gas. I'm sure that 93 octane *might* be ok, but probably something a bit higher and more expensive would be required. Also, there might be some issues with the piston - valve clearance.
Play it safe, just get a thinner head gasket (Spoon) which will help out your compression gains.
12.5:1 is no problem with 93 octane... basically all you need to do is get a thinner head gasket and if thats not enough ..you would have to mill the head, to get that kind of compression... another way would be to welding the combustion chambers , that is welding aditional material to the quench zones of the combustion chamber to increase the amount of quench and to increase CR ( compression) ratio. This produces more turbulence in the chamber , thus promotind better mixing of the fuel air mixture as the piston approaches TDC. and ofcourse the other way would be high cr pistons.
OK... I give up. What do y'all know that I don't?
1) How can raising the compression to 12:1 or higher work on 94 octane when people complain of detonation, stock, on 92 and 93 octane? From what I've read, a compression bump that drastic would require MUCH higher octane than that.
2) Why are you (Shamu) confident you can run 12.5:1? Or is "proper equipment" a lower temp t-stat, programmable ignition and a/f...
3) Why do you want to bump that much? Just power?
I would suspect that 100 Octane gas would be required, but I don't have a good feel for what static CR = what octane on our motor. I find it hard to believe, though, that a 1-2 octane number drop would cause reduced power but a 1 point-plus bump in static CR wouldn't require more than a 1-2 increase in octane.
I doubt it would damage anything, though- but I would expect a loss in power. I would suspect most of the advance to be dialed out.
Maybe with some cooling mods... then again, I *still* think it would require a higher octane fuel.
very very true Wes -- and for the piston/ring set, you gotta wait a very long time!
I'm strongly considering the head gasket, but I'm wondering if it's worth the install effort....anybody with experience with the Spoon head gasket?
Sticky Dipstick
Aug 14, 2005 03:27 PM
