Compression test numbers
Old Jul 17, 2010 | 12:54 PM
s2kbtos's Avatar
Default Compression test numbers
so i did a compression test on my car today.... i did a dry test and a wet test with a tespoon of oil in each cycinder.
DRY WET
1- 197 215
2- 185 200
3- 191 215
4 191 215
so what do you guys see wrong with this.....
please let me know.
Old Jul 17, 2010 | 12:56 PM
s2kkkkk's Avatar
needs ring job or engine rebuild.
Old Jul 17, 2010 | 01:41 PM
Moddiction's Avatar
Former Sponsor
Yeah rings are looking pretty worn. Probably can still drive it for a good while though.
Old Jul 17, 2010 | 01:49 PM
R3DS2K's Avatar
was the engine warmed up? did you have the throttle open all the way. did you remove all the plugs before testing.
pretty even numbers
Old Jul 17, 2010 | 02:00 PM
s2kbtos's Avatar
it wasnt warmed up, and ya it was at open throttle.
Old Jul 17, 2010 | 02:03 PM
Tanikins07's Avatar
Could be a valve adjustment as well. Have you ever done one?
Old Jul 17, 2010 | 02:10 PM
R3DS2K's Avatar
should do it again with it warm. it makes a huge difference
Old Jul 17, 2010 | 02:40 PM
s2kbtos's Avatar
will it make a difference on the wet test?
i did the valve adjustment like 20,000 miles ago.
Old Jul 17, 2010 | 02:52 PM
R3DS2K's Avatar
both dry and wet will be effected but all compression test should be down with the engine warmed up
Old Jul 17, 2010 | 05:32 PM
Tanikins07's Avatar
Have you done a leak down test to see where it's losing compression?
