Compression Tester Dropping Pressure after I stop cranking?
Old 10-29-2015, 11:55 AM
usmarinedelta's Avatar
Default Compression Tester Dropping Pressure after I stop cranking?
Hello,
So there is a local guy here and I was doing a compression test on his car. The results are as follows.
Starting with the cylinder closest to the front bumper (Cylinder 1?)
180
180
210
240 (then it starts dropping in psi slowly as I stop cranking, If I keep cranking it goes higher and higher)
I assume there is a leak? We've put a cap full of Lucas thick oil stabilizer in the cylinder and it still does the same thing.
Questions:
Would a valve adjustment solve this issues? I drove the car and drove it hard, no issues what so-ever.
Also what does it mean when the numbers go up as the cylinder # is going up?
He is using 10w-30 oil. Maybe he should switch to 10w-40?
Thank you.
Old 10-29-2015, 12:52 PM
Habitforming's Avatar
It sounds like the check valve in your tester is bad. I'd address that first.
Old 10-29-2015, 05:40 PM
Either I'm not understanding your problem, or you have bad luck with gauges. A compression tester should have a one way check valve in it, such that the pressure developed on each stroke is added into the chamber. No matter what the engine does, it can't remove pressure from the gauge. That's why it has the relief valve on the side.
If your gauges aren't holding pressure, there must be an issue with them. I don't see any alternative.
Old 10-29-2015, 05:42 PM
Also, is the engine warm when performing the test?
The next step will be a leak down test, to determine where the cylinder is losing pressure.
A valve adjustment is never a bad idea, so long as you know what you're doing. But there's no way to know if that will resolve your problem without doing the leak down test first.
And if you're a Marine - Thank You for your service!
Old 10-30-2015, 06:46 AM
shind3's Avatar
are you doing it with the fuel injectors unplugged? maybe fuel is getting to the seal by the 4th cylinder and ruining the gauge?
Old 10-30-2015, 08:32 AM
Car Analogy's Avatar
Received 1,304 Likes on 987 Posts
...and to prove if its gauge or cylinder, you should have tried one of the 'working' cylinders again. Do those still hold pressure, but cyl 4 still does not?
If now none of the cyl will hold pressure, then gas broke gauge theory sounds right.
Sent from my SM-G920P using IB AutoGroup
Old 10-30-2015, 10:09 AM
Honestly this is all a distraction anyway. Wether cylinder 4 is 220 or 240 is irrelevant- it's clearly healthy. Time to focus on 1 & 2. Either do a leak down test, or a valve adjustment, but stop worrying about #4 for now.
Old 10-30-2015, 05:23 PM
windhund116's Avatar
Received 1,423 Likes on 954 Posts
Agree. Do a leak-down test on all four cylinders & report back with results.
Old 10-31-2015, 11:04 AM
Originally Posted by usmarinedelta
#4 is the one that is causing the leak hence the need to figure out why. I will redo his #4 cylinder then another one to see if it's the gauge which I don't think it is, again I used both brand new gauges and same thing happened.
Again, nothing the cylinder does should have any impact on the gauge losing pressure. That is 100% the function of the check valve on the gauge. If it is losing pressure, perhaps it isn't designed to hold 240psi, thus why both gauges did the same (were they the same brand/model?).
Your focus should be on the cylinders with 180 psi.
Old 10-31-2015, 06:12 PM
THE REAL DEAL.'s Avatar
are you resetting the compression tester ?
Quick Reply: Compression Tester Dropping Pressure after I stop cranking?
