confused by answer at dealership...fluid change or flush?
Old Mar 26, 2013 | 10:27 PM
2009 s2k's Avatar
Default confused by answer at dealership...fluid change or flush?
So i was at the dealership picking up coolant and an oil filter when i decided to ask the service department about cost to do my transmission and diff fluid change. They gave me 2 different price, for simple drain and fill, or flush and fill.
Now i only have 15K, so know changing trans and diff might be a little premature (manual says 30K), but i just got the car so I want a baseline for the summer. I never read on these forums about people getting a flush done to their trans or diff...is it overkill? I am definitely not considering it, but it has me wondering a bit
Old Mar 26, 2013 | 11:51 PM
s2cho's Avatar
If you have a level surface save some money and do it yourself! Literally takes a hour for both, or a little longer for the first time.. My dif took about 2 hours cause i was running around trying to get a open wrench 23mm (I think) for the filler bolt which no one in my area had... But flush means they put some fluid through the top and allow it to drain down. Fill means that they drain and just fill it up. I would just go for the fill because the flush isn't worth the extra price considering your mileage. If the flush is over 5 bucks more don't even think about doing it! Its a rip off!
Old Mar 27, 2013 | 01:59 AM
INDYMAC's Avatar
Your service advisor thinks you have an automatic transmission. I recommend that you DIY, or take it somewhere that knows something about an S2000.
Old Mar 27, 2013 | 03:17 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Do not flush your dif or trans with anything.
Drain and fill is the best for your car.
Dealer is the worst for your car.
ANY fluid drains are best done immediately after a long drive. The fluid drain fast, but more importantly contaminants are lifted into suspension in the fluid, so the drain out with it.
If any dirty fluid sits dormant, contaminants fall to the bottom and stick to the metal and they will not drain out.
Old Mar 27, 2013 | 03:57 AM
takeshi's Avatar
^ This. Don't let them anywhere near your diff.
Old Mar 27, 2013 | 04:24 AM
redlineracing's Avatar
Yep!!
The trans & diff is an ez process.Both should take less than an hr.
\rlr
Carolina
Old Mar 27, 2013 | 07:14 AM
apme123's Avatar
I repeat, do not take your car to the retarded stealership. They really dont know what the heck they are doing.
Old Mar 27, 2013 | 11:04 AM
s2000maniac's Avatar
The hardest part is getting the car on 4 jack stands
Old Mar 27, 2013 | 04:35 PM
boston5520's Avatar
I've worked at dealerships and independent shops. The independents are much bigger thieves than the dealer. You can not flush a diff or manual trans just drain and fill. If you have any mechanical ability you can do it very easily and also choose what fluid goes back in it
Old Mar 27, 2013 | 08:51 PM
2009 s2k's Avatar
Thank you for the replies. Yea, i never heard of a flush done on these diffs and trans, so i was just seriously confused and had to bounce it off everyone here on the forums. For sure not letting them touch the car, especially since it seems so easy (thanks to all the info from the forums).
thanks for clearing the air on this for me
