Consensus on brake rotor set screws?
Old Jul 18, 2011 | 12:08 PM
  #41
hirev's Avatar
I did my front brakes over 1.5 years ago, drilled the screws out, if I have thought of the freeze method would have tried that. did not give them a minutes notice, came right out and never put back, no issues with front brakes. drill'em throw 'em away.
Old Jul 18, 2011 | 04:22 PM
  #42
Clark's Avatar
Please please please do not even go there.
There is absolutely zero chance that not putting those screws in will cause anything on your car to fail in any way. The closest leap of logic one could possibly even make out of that is that somebody inadvertently cross-threaded some other mounting bolt (which still usually doesn't cause a failure) while they were hastily changing rotors and that maybe putting these screws in place could have prevented that form of human error.
That is an Olympic level triple-jump of logic.
The only reason they were ever put on the car was for efficiency in the assembly process.
Originally Posted by WarrenW
Originally Posted by SpitfireS' timestamp='1240946509' post='16063125
This is what you DO need to put on them if you put them back.
Impact screwdrivers and punches are what you don't need if you put on what you do need.
And don't overtighten.
But you might as well leave them out.
People here may say it's not needed but after the accident that killed Cale I would put them in. After I had to get mine out with an Easy Out, I put the new ones in with HIGH TEMP anti-seize compound. I don't know exactly what happened that cause the brakes to fail on Cale's car but why take chances. If it was put there by the factory, I'd say put them back in.
Old Jul 18, 2011 | 05:35 PM
  #43
RedY2KS2k's Avatar
CRC sells a penetrant with "freezing action." I've never tried it, but it sounds interesting. If I ever come up against a screw/bolt I can't remove I'll have to give it a try.
Anyone else have any experience with this product?
Old Feb 10, 2014 | 10:48 AM
  #44
ap1s2k808's Avatar
Originally Posted by Clark
Trust me, the chisel trick works way better and faster than any drilling.
I really really have to agree with this. Like 3 days ago, I actually tried drilling and extracting these screws. After about 5 minutes, I did the chisel trick and, they all gave way very quick, i was able to finish backing them out by hand.
Old Feb 10, 2014 | 12:29 PM
  #45
Fokker's Avatar
You need a better drill and/or bit if that chisel trick is faster. Drill the head out, never worry about them again.
Old Feb 10, 2014 | 12:50 PM
  #46
Chris_Lum's Avatar
I can drill them out in less than 1 minute each (that includes a pilot hole with a smaller bit, then switching out to a larger bit). I hate those things...
Old Feb 10, 2014 | 02:34 PM
  #47
c130turboprop's Avatar
as soon as i buy a different car, i take the wheels off and i take the screws out, lol.... then i go ahead and take the main caliper and braket bolts out and antisieze the crap out of them. nothing more frustrating when u wanna do a brake job in a day and the stupid screws wont come out or bolts are seized up
Old Feb 11, 2014 | 08:25 PM
  #48
2003AP1's Avatar
Originally Posted by Billman250
Heres the method that always works. Been doing it for 20 years.
Fabricate a punch, the exact size as the screw head. it must be perfectly square.
Holding it nice and straight, give it 3 shots with a 4 lb sledge.
The screw will now be loose...even though you did no turning action on it.
This works. I heard similar things being done with two ball pein hammers.
I stil use the impact driver though.
Old Feb 11, 2014 | 10:53 PM
  #49
marshman's Avatar
Had to do a bearing assy on my left rear and those 2 took me and another person a day to figure out but got those 2. I recently got rotors and just drilled out the other 6 after I briefly attempted them with pb blaster and impact driver. Used an 18v dewalt with a Fastenal bit. Cakewalk. But for some reason I put back the 2 in the left rear. Lol
Old Feb 12, 2014 | 09:09 AM
  #50
yamahaSHO's Avatar
I've never had a problem taking mine off with an impact screwdriver. I do reinstall with some anti-seize and only snug them down. I know they're not needed as many cars don't use anything to hold the rotors on, but it's nice when you work on the brakes at times. When I upgraded my front and rear brakes to Wilwood kits, I went ahead and bought all new screws.
