Correct timing
How to put my cam shaft And crankshaft in (tdc) correct timing. My s2k won’t start and I think it needs to be put In correct timing. Thanks. |
Was the engine taken apart recently, and hasn’t ran since? |
Yeah |
Originally Posted by Billman250
(Post 24484624)
There's an illustration in the Service Manual. It's even on Page 6-12 of the manual commonly on line with the Japanese bikini model on the cover.
-- Chuck |
Originally Posted by Chuck S
(Post 24484876)
-- Chuck |
Originally Posted by Boosted04S2K
(Post 24484881)
Originally Posted by Zack Atkinson
(Post 24484884)
ok I see how would I turn the gears for the camshaft on the intake and exhaust clockwise or counterclockwise? And also how would I turn the gear for the camshaft? Using a wrench or some kind of special tool? Should I take out the spark plugs when I do this? Just wanna make sure the installation is done right. Also how would I test it to make sure its right besides trying to start it up? Thanks for the help |
19mm socket on the crank pulley and turn it clockwise, you don't need to remove the spark plugs but its much easier to turn the engine with them removed.
Originally Posted by flanders
(Post 24484906)
