Crack near rear camber eccentric bolt
I have had the car for 4 years and track the heck out of it. I have had a ton of alignments and I think a couple times they had to get a pry bar in there to free a stuck eccentric. I always emphasize being careful and I think they always are, so I am not sure that anyone who has recently aligned the car did this or if it happened before I owned the car. I have had the car apart a lot and usually am real observant so I am surprised I just noticed this.
To me it looks like the result of a pry bar vs driving force, I tried to get an idea if it goes under the plate, I don’t think it does. It really looks to me like it is old, someone even put an epoxy on it at one point.
Any my thoughts if I should be concerned? To me it doesn’t look structural just the outside edge from a pry bar, but I can’t be totally sure.
The S2000 is as thin as f**k there I would get it reinforced & welded before tracking /driving the car for sure..
its had a right going over with a lever !! and stressed and bent.
Get it plated
Get it plated
Would also add it would benefit from a better structure here, as the gusset that Spoon does for the mountings to top A arm that rip away from body.
Could better idea maybe get another subframe the adjuster looks way out also and accuracy for geo may have been an issue..
& the Horror !!
spent x hours hoping mine would not look like this after my diy bush install !!
get another shop to do your fine tune whom uses anti sieze grease ..........
To be fair I am pretty sure I have tracked the piss out of it like that. I just can’t decide if there is actually any driving force right there. You have all the ball joints then bushings, to me it seems more like a pocket.
I am thinking I will likely weld it up, the control arm will need removed. I may wait till after the first couple events, I really don’t think it will fail. Dropping the subframe sucks balls, I actually did it last year, too bad I didn’t notice this issue!!
But lateral forces on this area will not help,it may not snap due to the thin gauge metal.
I was bending the area by hand holding the lca without the caster connected and thought of plating whithout a fracture like that.
If needed just get a little weld in situ,and spay with water to cool the area,it should hold
I noticed this problem on my front subframe so I removed the adjuster brackets (drilled out the two spot welds) and had a local engineering shop machine
4 new ones out of a billet mild steel, no way can these bend out of shape now and only cost £100 for all 4.
Nickfromny
06-15-2005 05:27 AM
