Cracked Compliance bushings
While doing some work on my car I noticed the compliance bushings on both sides are cracked. I'm not sure how deep the cracks go but they're all over their surface. I'll attach a picture below. Will they have a negative effect on the car, in their current state?
IMG_1149
IMG_1149
These are usually the first suspension bushings to fail on our cars. The caster adjuster in the middle of the bushing also sieze often. Unfortunately Honda doesn't sell replacements they force you to get the entire control arm, but Mugen and Spoon sell OEM like bushings (slightly stiffer than stock) or you can go with a polyurethane or spherical setup
I had one bushing fail so I replaced both with Mugens - I didn't notice any difference in feel to be honest
My opinion is they show age, yes. From the one photo shown, and I didnt zoom or anything they are Ok, not great. If you want to get technical yes, it would effect performance to a small degree. Really need to look out for cracks that go all the way through or appear to be close to going through. It would be worth considering replacing them sooner just to avoid inconveniences. AKA set up a day where it can be done where you don't need the car or whatever. My 2 cents. Somebody more experienced should chime in. More photos maybe.
If Mugen/Spoon have OEM like bushings then I assume their life expectancy would be like OEM? My car is an 02 with 49k miles. How do the polyurethane/spherical compare to the OEM? I'm not sure if I really care about what I'll "feel" with the new bushings but I definitely do not want something that will squeak or require maintenance. Which one do you guys recommend?
My car isn't my DD and also I'm planning on replacing the front sub-frame over the winter so I might as well replace the compliance bushings at the same time.
They looks fine to me. They are not even close to warn out and I would not consider your bushing bad at all. I have seen s2000s with 20k miles and they have those tiny surface cracks on the compliance bushings. Even my 02 ap1 with 125,000 miles looks like yours and it's looks like they even at 50k miles when I baught the car.
Those aren't too bad. But if you are going to be replacing subframe, then yeah, I'd do these then for sure.
If you want zero maintenance, then get the mugen ones, not any of the poly types. Those would require some relubing from time to time. Many find its no big deal, but it ain't zero.
You need to press the old ones out, new ones in. There is an arrow in the rubber to show which way they go in. Arrow must point to the front bushing. Think of the arrow as if it were the bushings pivot that must be in line with front bushing pivot (front bushing bolt).
I mean TBH...No one here can tell you if they are good to go or not. When you have an alignment done the tech will be able to tell if they are shot or not. They will flex very easily if they are worn out.
Worn compliance bushings can cause wandering on braking, unevenly worn tyres even after aligning, an alignment that won't hold spec, clunks, bumpsteer, or instability.
Any of that going on? If so...replace them with a suitable RUBBER bushing from Mugen or Spoon.
I would not buy the cheap polyurethane solid disc shaped bushing. Its a compliance bushing. It requires movement, deflection, and articulation. Solid poly would tear very fast and the constricted movement would make the car feel like shit.
