Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
CrankPulley Woodruff key orientation
Notices
Old 03-03-2019, 04:17 PM
F1TwoThousand's Avatar
Liked 13 Times in 13 Posts
Default CrankPulley Woodruff key orientation
Took this out and didnt pay attention how it was installed. Any one rememberm
does the tapered side go towards engine block or pulley?
F1TwoThousand is offline
Old 03-03-2019, 04:32 PM
zeroptzero's Avatar
Liked 79 Times in 78 Posts
tapered end towards the block , the square end flush with the outside end of the pulley where it meets the bolt.
zeroptzero is offline
Old 03-03-2019, 06:51 PM
Thanks! Tapered side facing up or down towards the block? I tried sliding it in i wonder if the crank has to be at top dead center to slide the woodruff key back in. Ill take alook tmrw
Old 03-03-2019, 06:58 PM
zeroptzero's Avatar
If you look at the end of the crankshaft slot you will see it tapers as it gets closer towards the block and the taper is upwards, so the key goes in with the tapered side facing down and the two tapers fit each other tight so the key doesn't slide too far back. You can put the key in the channel with the tapered side facing down and towards the block, and then slide the pulley over the key.
The following users liked this post: zeroptzero
F1TwoThousand (03-03-2019)
Old 03-03-2019, 07:01 PM
Really appreciate it, i shouldve paid more attention when removing it. I figured it was part of the crankshaft and nearly $#%# myself when it popped out when removing the pulley
Old 03-03-2019, 07:08 PM
zeroptzero's Avatar
No worries, I just took apart my B-series Integra for a timing belt change, I had one key for each cam and the crank uses two keys, my biggest challenge is not losing the keys after they come out. They are so small and always seem to drop on the ground at inopportune times, lol. I refer to them as tic tacs
Renze
09-14-2013 01:03 PM
Silvers808
02-28-2007 01:10 PM
C6400hp
05-25-2005 07:40 PM
brandonb
12-29-2001 12:24 PM
Quick Reply: CrankPulley Woodruff key orientation
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
