This is crazy, but Oil Burn? The Story of conquering phantoms.
#111
Thomas Guide, redo the smoke test with the intake blocked off where you removed the filter. You could use just Saran wrap or something like that.
Imagine trying to test your garden hose for leaks with no sprayer attached to the end, just letting the water spill out the end. With no pressure building up, water won't have much incentive to force its way out the leaks.
#112
#113
I've now read through this whole post and it sounds like a possible simple fix to a nightmare problem... if it works. (Hoping it's not like the mythical shin etsu grease "fix" for roof leaks ).
I had a compression test carried out on mine a year or 2 ago and the numbers were fine and consistent across all cylinders so this could be light at the end of the tunnel for me.
Thought I'd compile the parts list in this post:
PCV Valve grommet - Honda Part Number - 17139-PK1-000 - £4.96 - https://www.lingshondaparts.com/part-search?partnumber=17139-PK1-000
New Dip Stick - Honda Part Number - 15650-PCX-006 - £41.69 - https://www.lingshondaparts.com/part...=15650-PCX-006
Oil cap gasket - Honda Part Number (please check this) - 15613-PC6-000 - £8.56 - https://www.lingshondaparts.com/part...ber=PFKL315510
Please double check these part numbers are correct as I have had to reverse Lings own number for the oil cap gasket and Google'd the others.
So far this total is £104.48 with all parts direct from a Honda dealer.
However I wonder about replacing this rubber part that has been posted a few times in this thread, what is this part?:
EDIT / ADDITIONAL INFO: Here is a link to my original thread from 5 years ago (when I was tracking oil consumption). https://www.s2ki.com/forums/s2000-un...miles-1090768/
- New oil cap gasket (old one was so flattened )
- New dip stick (because you can't buy the gaskets -- old one was SUPER loose )
- New PCV valve and PCV gasket ()
https://www.s2ki.com/forums/s2000-un...meter-1191700/
You probably don't need to replace it unless it's cracked, Honda sells this tube as a bulk hose, so you get 4 feet of it and just cut what you need. I would recommend replacing all the other little Orings and gaskets that Deckoz mentions instead.
#114
Ok thanks Thomas, so updating this list again:
PCV Valve - Honda Part Number - 17130-PV3-013 - £49.27 - https://www.lingshondaparts.com/part...=17130-PV3-013
Breather Tube Hose (you get 4ft worth) - Honda Part Number - 95005-12001-10m - £66.26 - https://www.lingshondaparts.com/part...5005-12001-10m
All gaskets on the valve cover and all gaskets on front timing cover:
TCT O Rings
VTEC Solenoid Gaskets
Valve cover Gasket
Spark Tube (x4?)
Valve Bolt Gaskets
VTEC Oil Pressure O-Ring
TDC O-Rings
TCT Peep Washer
Cam Idle Gear O-Ring
Valve Stem Seals !
Optional Extras?
(2004-2005) Cylinder Rocker Cover - Honda Part Number (please check this for model year - I have searched a 2005 here) 12310-PCX-010 - £628.25 - https://www.lingshondaparts.com/part...ber=PFKL273137
(TSX PCV to go with updated rocker?)...
So hang on a second, this isn't a "relatively cheap" fix for most people if you still need to have your valve stem seals done too, just a warning that there are some extra steps including having these replaced?
TCT O Rings
Valve cover Gasket
Spark Tube (x4?)
Valve Bolt Gaskets
TDC O-Rings
TCT Peep Washer
Valve Stem Seals !
Optional Extras?
#115
I'm still wondering if anyone has done compression and leak down tests before and after fixing their crank case leaks. According to the theory of this thread, compression and leak down should improve after sealing up the crank case, right? Or am I just crazy?
Here's my thought process. Car is burning oil, and has a leaky valve cover/oil cap/dip stick/etc. This means oil is getting past the piston rings and up into the combustion chambers. After fixing the air leaks related to crank case pressure/vacuum, car stops burning oil. So this means that the proper amount of crank case vacuum is needed to make the piston rings seal properly. With this being said, shouldn't compression numbers increase and leak down numbers decrease as well?
#116
TCT O Rings
Valve cover Gasket
Spark Tube (x4?)
Valve Bolt Gaskets
TDC O-Rings
TCT Peep Washer
Valve Stem Seals !
Optional Extras?
TCT O Rings
Valve cover Gasket
Spark Tube (x4?)
Valve Bolt Gaskets
TDC O-Rings
TCT Peep Washer
Valve Stem Seals !
Optional Extras?
#117
As well to your comment, burning oil doesn't always mean ring seating. Which is why I mentioned valve seals at one point to. Positive pressure in the crank case, with bad valve seals, is going to push oil past the seals down the guides and into the runners.
Its not as simple as static leak-down and compression tests. But if your test come out good, like mine(210psi across the board on an ap1 f20 - 5 crank compression test, and 6-8% leakdown). And you are burning oil, then the point of this thread should make some sense. Solve crank case pressure.
As I'm pretty sure I mentioned this earlier, it doesn't matter much on boosted cars, as they hardly ever have vacuum in the combustion chamber, and the pressure in the cylinder is higher than that of the crankcase, during the intake down stroke, keeping pressure on the rings.
#118
I can redo mine this weekend possibly if I have time... Compression shouldn't change much, and neither should the leakdleak. The theory is about moving pistons not stationary pistons. During the intakeintak stroke vacuum is on both the cylinder and crankcase, the pistons must be displaced. When the crank case has low vacuum or positive pressure, but the cylinder has vacuum, oil can get by the rings easier.
#119
please help again here, my engine might be bad
https://www.s2ki.com/forums/s2000-un...1190696/page5/
