This is crazy, but Oil Burn? The Story of conquering phantoms.
#32
true, unless are doing a Kpro conversion sensor swap, which switches to 06-09 single TDC if I am not mistaken
#35
I'm chasing the same exact oil loss thing and this past weekend changed out all the gaskets and O-Rings (dipstick, both TPC, new PCV... etc) and am monitoring but this test is exactly what I've been looking for to help narrow down the leak.
thanks Deckoz!
#36
Can you elaborate just a bit more on this please, still not clear...how do you 'block off the pcv'? Or 'ensure it is functional first with the engine off'. I'm just not clear on these instructions before injecting 3-5psi in... do you just stick an air hose nozzle into the breather tube?
thanks Deckoz!
thanks Deckoz!
You want the psi to stabilize but continue to output, so that the noise stops being produced by the hose, as the pressure in hose and engine are equal, leaving the air escaping the engine as the noise producer.
its the same principal as a leak down, but low pressure and only listening for the air escaping, vs trying to meaure it...
#37
To block off the pcv, you would simply take a short section of rubber hose, and jamb something in it to seal it off. A golf tee, a bolt, whatever. Then plug this into pcv in place of its usual hose.
Because of this thread, I purchased a new oil filler cap o ring from the dealer (Majestic, online). It was just a few bucks. The old one was hard and stiff. It was always very difficult to unscrew the oil cap. Now you can feel the new o ring compress as you tighten cap, and it comes off easy. Its easy to see how I could have had an air leak.
Everyone with oil consumption issues should replace their oil cap gasket. Its low hanging fruit.
#38
@Deckoz , @Car Analogy : Would injecting smoke into the front breather be a better option for ease of detection? If so, can you idle the car using your method and do this or would it cause problems?
Or alternately, how would one use a smoke machine to test for a leak? Meaning, where do you stick what where...
Thanks, this issue you have is something I'm actively trying to figure out with mine as well.
#39
Had a customer report that his oil cap gasket fixed his oil consumption.
Any seal that affects crankcase pressure can affect the rings ability to seal.
-oil cap
-pcv valve
-dipstick orings
-oil cap
-pcv valve
-dipstick orings
Can someone post a photo of the underside of the oil cap and it's gasket? Mine's flat. I would assume there would be a slightly protruding gasket but it seems like there is a soft rubber gasket that's along the flat underside of mine, so I'm not sure if I've got it or not.
