Crossthread doing shifter regrease. Now what?
Old Oct 13, 2024 | 02:14 PM
MrCrossThread's Avatar
Default Crossthread doing shifter regrease. Now what?
Decided to re-grease my shifter this afternoon and all went fine. When reinstalling it can be a bit of a bitch to press down against the spring and thread the initial bolt. I got it on and tightened it down but about halfway through it got significantly harder and harder to tighten as compared to the other two. Pretty sure I cross threaded it, do'h. Not knowing much about the assembly of the transmission, what would you do? Just leave it and never do a re-grease it again? Worth re-tapping it? From what I recall there was another bracket with 4 bolts, any chance to remove that and replace?
Old Oct 13, 2024 | 04:02 PM
Slowcrash_101's Avatar
Try a thread chaser see if you can clean it up.
Old Oct 13, 2024 | 05:18 PM
Car Analogy's Avatar
Yeah, thread repair tool, not tap.
Tap cuts away any metal that isn't where its supposed to be. Thread repair tool reshapes the metal back to where its supposed to be.
Look for a thread repair kit Amazon
Old Oct 14, 2024 | 06:37 AM
windhund116's Avatar
Yes. I use a lot of 3-in-1 oil to clean all the metal bits left behind while chasing. Then, try the threads without any spring tension to be sure they're good.
I like a little grease on the threads to help with the final tightening.
Good luck!
Old Oct 15, 2024 | 08:34 PM
bad_driver's Avatar
Future hack for future you:
Shift it into reverse. It will lock the spring.
Old Oct 16, 2024 | 06:47 AM
SheDrivesIt's Avatar
Do you put the shifter in reverse before you take it apart?
Old Oct 16, 2024 | 07:06 AM
bad_driver's Avatar
You do it after you take it apart, just when you are attempting to put the bolts on.
Old Oct 16, 2024 | 07:13 AM
thoiboi's Avatar
Genius! Saving this for future use
merkis1024
Sep 10, 2023 08:43 AM
Brailer
Jul 13, 2019 03:31 PM
mackasaurus91
Oct 7, 2014 01:23 PM
tylers2000
Jan 19, 2013 02:22 PM
Incubus
Nov 11, 2002 11:25 AM
