Cruise not working
The button wont light up. Already checked fuse 47. Has anyone had a module go bad? Thanks.
It is almost always the white nipple under the pedal that breaks. It's a cheap fix.
Originally Posted by Bamafan
(Post 24244404)
It's the little plastic part on the clutch pedal that makes the cruise control think the clutch is depressed.
-- Chuck |
why does cruise control even exist in our cars??
Originally Posted by panda25
(Post 24244428)
(Post 24244404)
Pretty sure it's under the clutch pedal. Not under-under but up top were the pivot is.
There's an electrical plunger up there that doesn't get depressed (or pressed?) when this part falls off and the cruise control thinks the clutch is depressed and kills cruise like it does if you change gears. -- Chuck |
That part falling off probably wouldn't cause the activation light to go out when pressed would it?
Cruise control -- and air conditioning!, things those Brit roadsters of long ago never had-- are vital on long drives of (say) several hundred miles. Unless you want to be "that guy" whose highway speed is constantly varying and making the, admittedly few, guys behind you nuts.
Keep the spend constant while you're texting as well. :) Set it for the speed limit and when your Valentine 1 goes off just lift off the gas pedal and you're all nice and legal. -- Chuck |
