Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Cylinder #2 rod bearing failure again :-(
Old 07-22-2018, 10:07 PM
Default Cylinder #2 rod bearing failure again :-(
So my last post included a video clip which turned out to be confirmed as rod knock. Needless to say after the time and cost $,$$$ to rebuild after originally spinning the rod bearing on cyl #2, I am disappointed and contemplating letting go of my S2. All new OEM parts including pistons, con rods, rings / bearings, $2K machine shop work including freshened head........all lead to failure. The one component, the crank, I had reworked, spec'd, nitrided......I believe is the suspect cause of failure. Either the bearing was not properly spec’d (highly unlikely and shop checked everything) or the oil supply on that journal isn’t flowing. Inspection of bearings on cylinders 1, 3 and 4 all look great. The journal on #2 looks great, no scoring or marks. So now I believe I need to most likely replace the crank. Full tear down and cost of a crank is pushing the rebuild into stratospheric costs. Attached are pics. Bearing failed after 600 miles while using high end break in oil. Feedback on solutions or approach to fix would be immensely appreciated. A year and over $5K, I’ve reached a threshold.
L8BRAKN is offline
Old 07-22-2018, 10:09 PM
Default Photos
L8BRAKN is offline
Old 07-22-2018, 10:22 PM
My guess is that Billman could read this situation better than anyone under the circumstances. My God this situation sucks! I realize how huge it is financially, believe me. Best of luck!
DesertWanderer is offline
Old 07-22-2018, 11:24 PM
There are some very good PDF Documents form Companys like MAHLE, CLEVITE out there that picture in detail every possible engine bearing damage and describe the reason.
Do a google search, this forum dont let me post the links to ths PDF Documents.
I would also send pictures from this bearing to this companys and ask for theyr opinion what causes the damage.
Mr.Matchbox is offline
Old 07-23-2018, 02:56 AM
Billman250's Avatar
Improper crankshaft service. The crank needs to be beyond mirror perfect. Who built the motor without replacing the crankshaft?
Billman250 is online now
Old 07-23-2018, 04:11 AM
So they reworked the original crankshaft?
fatjoe10 is online now
Old 07-23-2018, 09:48 AM
must you always replace the crankshaft, or only if there is a reason to when rebuilding?
jyeung528 is offline
Old 07-23-2018, 10:31 AM
I've had a few crankshafts serviced. There is no issue as long as you dont go over .002". The biggest issue I usually see is the main journal bores on the block going out of round. If you only had one rod bearing go that badly and that early either the bearing clearance wasn't set correctly or the rod was over/under torqued causing the bore on the rod to be out of round.
Charper732 is online now
Old 07-23-2018, 10:41 AM
Also possible the rod is not round on the big end, would plastgage ok but fail. Was common problem on CBX motorcycles that hydro locked from carb float issues.
just an idea no knowledge of this problem occurring on S2000
Mnstr2000 is offline
Old 07-23-2018, 11:57 AM
engifineer's Avatar
Once a motor has chewed up a bearing, I would have leaned towards a new crank. Surprised the shop did not, but its hard to judge not knowing what they found when they inspected everything.
engifineer is offline
Quick Reply: Cylinder #2 rod bearing failure again :-(
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
