Cylinder # 4 Misfire was told broken piston rings
Hey everyone,
I am trying to figure out a plan of action for the current issue I have with my car.
Around December I started noticing a slight misfire on cold start, it would ring up as misfire on all 4 cyl but at the time it was very rare. I would say once a week or 2 weeks..
I figure it was time to do a tune up so I went ahead and ordered 4 coil packs along with spark plugs, also ordered a gator back belt along with other misc gaskets that needed to be replaced like the front O ring and etc.
Problem persisted so I got on here and started doing some research, came up that injectors could be clogged up and maybe the cause of this so I went ahead and got all my injectors ultrasonic cleaned and replaced the o rings along with it.
Again, the problem persisted so the shop I took the car to did a compression test and they came back to be 210 210 180 140 (140 beign cyl # 4) they told me they did a wet test and compression jumped up to 180 so they suspect it would be broken piston rings and suggested a motor rebuild or a swap.
What im trying to figure out is why is it only on cold start and why when the car is warmed up it runs fine.
I have an 04 ap2
118,920 miles
Intake and exhaust
car does not burn oil at all neither it smokes on idle or while driving.
I have had this car for 3 years and It has never given me any issues, I have done all the maintenance myself and kept the car very well cared for.
your input will be greatly appreciated!
thank you all
darks2k
I have an 04 ap2
118,920 miles
Intake and exhaust
thank you all
darks2k
Valves adjusted? Did they do a leak-down test?
Would suggest a bore scope to see if any bore damage has occurred.
NFRs2kevin
02-26-2010 03:24 PM
