Dealer did not tighten oil drain plug-total oil loss
on a lighter note... watch this yotube video of guy running this poor mitsubishi without oil trying to destroy it and it runs like that for very long time! Not saying it was good for your s2000 in anyway but just for peace of mind.
https://youtu.be/3WLOccckJ5o
Ehh damage happens when it heats up too much. Oils job is to cool and lubricate. If it cannot cool then therefore it cannot lubricate. Even if all the oil went out the pan, the film of oil on the moving parts would still do an adequate job for a little while. Did you ever go above 3 bars in the coolant temp?
When you pulled over was there a puddle of oil under the car or had all of it already drained out? ...did you see a line of oil to the point at where you pulled over? If the answer is no then odds are it did wear on the bearings some...how much, you won't know unless its plasti-gauged. If you decide to just run the car as it is, I advise you come to some kind of signed contract agreement with the shop stating they will cover damages if the engine fails in the next XXXX miles
Any momentary loss of oil pressure in VTEC will instantly destort the connecting rod bearings, and they will eventually spin. If you were only cruising, you might be ok.
That dealer owes you an engine. Sad part is that the damage may not be evident for some time.
Hiring kids with no experience is the dealers new way to save money.
There was a long trail of oil from where the bolt came out to where I stopped. It was draining for a few minutes after I stopped. The dealer did warranty the engine (in house, non transferable) for 2 years or 20,000 km. I don't drive it much (weekends only) and put about maybe 7000 km a season on it so I'm going to ramp up the driving so the distance expires before the time. Apparently it wasn't a kid who did the change but a tech who owns an S.
sounds like you got lucky.. if you could even walk back to spot where the oil slick started.
that brings me to another question, who safety wires their sump plug so this doesnt happen? ( i did that on my CBR but that has taller bolt and even had a dimple ready for drilling thru it.)
Not F1 standards granted, but this is good insurance policy
