delete
Old Feb 1, 2009 | 01:51 PM
F20Cdriver's Avatar
Default delete
delete
Old Feb 1, 2009 | 02:06 PM
cdelena's Avatar
The cat-back exhaust system is only there to direct the gases and quiet the noise. The cats are where the emissions are cleaned up so if you have not changed those you should be OK.
Old Feb 1, 2009 | 02:08 PM
F20Cdriver's Avatar
okay man, thanks.
Old Feb 2, 2009 | 05:46 AM
SSM_S2k's Avatar
so what about test pipes? will they pass smog tests even tho you dont have CEL? my O2 sensor has the spacer for it not to throw CEL.
Old Feb 2, 2009 | 06:24 AM
21337R's Avatar
That looks like vapor, not smoke. Probably just from the weather or possibly condensation inside the exhaust. Obviously it could be burning some coolant but you would be able to clearly smell that. Was this video taken after the car\exhaust had been sufficiently warmed up?
Also, FWIW when I had my '00 smogged here in AZ, they didn't even use the sniffers. They just plugged into the obd port and ran it on their dyno. Not sure what they do in Cali but I would guess that as long as you don't have a CEL you should be fine.
AngryTurtle's Avatar
as long as they dont do a visual inspection or sniffer.
Old Feb 2, 2009 | 07:48 AM
txchopper5's Avatar
in MOST any state, if your car has obdII then they just hook up to that and check the lights/mirrors/windshield/tires ect and if you have the cel fix you're good to go
if they have a reason to put it on a lift they'll see the pipe, or if you're in someplace crazy like cali they're all insane about stuff there so who knows, but most places don't even check if the obdII reads fine.
Old Feb 2, 2009 | 08:15 AM
R3DS2K's Avatar
you car looks clean. what kit do you have on there?
Old Feb 2, 2009 | 01:37 PM
F20Cdriver's Avatar
no, the car was not warmed up at all, actually the car had not been turned on for a week or maybe longer. also, the gas is pretty low right now. i'm not really sure if that had anything to do with it. thanks for the help.
Old Feb 3, 2009 | 09:55 AM
F20Cdriver's Avatar
thanks, it's a gp sports replica kit. i'm getting rid of it thougth.
