DIY Axle Nut TSB
6 Attachment(s)
Not sure if my MY01 ever had it's axle nuts re-torqued to the higher torque range so I decided I would do it anyway.
Things you'll need 1) 36mm socket http://www.amazon.com/OEM-25206-Sock.../dp/B000CMHKPY 2) 4 ft 1" pipe http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 3) Grease http://www.walmart.com/ip/Super-Tech...14-oz/16928004 Now park the car and chock the rear wheels. I put my car in reverse gear and pulled the e-brake. Remove your wheels center cap and you should see this: Attachment 201079 I didn't bother to unstake the axle nut. So get your socket firmly against the nut and put your pipe over the wrench like so: Attachment 201080 The nut broke free with little effort, I am only 160lb guy so the 4 feet of leverage really are a great force multiplier. Attachment 201081 Now wipe the face of the nut clean and apply a thin layer of grease on the face. Do not apply any grease to the threads. Attachment 201082 Its also a good idea to wipe the area where the nut is going to be against. Attachment 201083 Put the nut back on with your hand until its tight then use your wrench to get it as far as you can. It should be close to the original staked location. Now put your pipe back over your wrench and give it a good turn. Careful not to snap your wrench. The original stake location should move from 12 o'clock to 2 o'clock. As you can see the red line is the old stake point the blue is the new stake point. Attachment 201084 Repeat the other side. |
Awesome write up...i just have no time for pics :)
Keep in mind the clock positions are for cars that have never had the nut disturbed. |
Call dealer tell them vin honda has TSB records :) but good write up!
Originally Posted by Billman250
(Post 21339724)
Keep in mind the colck positions are for cars that have never had the nut disturbed. Good point, the stake positions will move from 12 to 2 o'clock if they have never been done before. |
Originally Posted by speedjunky01
(Post 21339726)
thanks for the write up, but I never understood the meaning of staking and unstaking the axle nut? anyone care to explain?
Originally Posted by Carbon Blue
(Post 21339768)
Stake the nut means to put a deformation in it so that it can't work itself loose. If you notice in the first or last picture the nut has a section dented in. That is the stake. |
ahhicic, thanks for the info!
so you have to remove the nuts? you can't just tighten it an additional 2'oclock? if it hasn't been done before. Or do you have to remove the nut?
by the way, thank you for the picture, very helpful :) |
:thumbup:
Nope, you do have to remove the nuts completely, to put grease on the face. Without the grease, you won't be able to torque the nut to the 2 o'clock position. -Connor |
| All times are GMT -8. The time now is 03:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
