DIY Valve retainer replacement with head in place
Old 05-02-2010, 07:13 PM
  #21
csaba6350's Avatar
When you loosen the valve adjuster screws before you remove cam cap bolts, do you loosen them all at TDC cylinder 1? Or do you crank the engine to get the cam lobe off the other rocker arms, and then loosen the other ones?
Old 05-03-2010, 06:06 AM
  #22
Billman250's Avatar
Received 1,253 Likes on 763 Posts
Originally Posted by jyeung528,Apr 13 2010, 07:09 PM
is it okay to replace the exhaust side with ap2 retainers using the stock springs?
Originally Posted by s2k_boy,Apr 14 2010, 03:13 PM
^ yes
No, it is NOT ok.
Old 05-03-2010, 09:39 AM
  #23
s2k_boy's Avatar
Originally Posted by Billman250,May 3 2010, 06:06 AM
No, it is NOT ok.
so you have to replace it with AP2 valve springs too? how bout intake side?
Old 05-03-2010, 04:00 PM
  #24
jbird's Avatar
would also like to know
Old 05-03-2010, 05:37 PM
  #25
Billman250's Avatar
Intake side gets AP2 retainers and keepers.
Exhaust side stays 100% stock.
NO AP2 springs on either side.
In theory, adding weight to the exhaust valves will lower the RPM needed to make piston-to-valve contact.
Over revs go like this on a stock AP1:
-Mild over rev: intake valves float, splitting the retainers (likely around 10k)
-more severe: at about 10,700 rpm, the exhaust valves contact the piston.
The purpose of the AP2 upgrade is to raise the retainer-split-rpm over the exhaust-valve-float rpm.
Bottom line, you do not want to lower that number (10,700)
So after the upgrade, your engine can withstand 10,600, instead of 10k.
TKY (04-29-2020)
Old 05-04-2010, 09:10 AM
  #26
s2k_boy's Avatar
got it. thanks for the info.
Old 06-15-2010, 11:27 PM
  #27
OneSilverS2k's Avatar
If you do not have air, after you remove the cam, can you rotate the crank to TDC fro each pistons so when the valve drops slightly it won't fall in? I don't have compressed air.. It was an idea, I could even put some string in there too so it does not hit the top of the piston.
Old 06-26-2010, 10:56 AM
  #28
Anyone? Can you answer my question above?
Old 07-24-2010, 05:33 PM
  #29
Does anyone know if you have to use F22 Cotters? I have the retainers, but I just didn't have the time to get the new cotters suggestions?
Old 07-25-2010, 06:43 PM
  #30
RobTheGob's Avatar
Yes - you need the AP2 cotters, if you use the AP2 retainers. The angles in the AP1 parts are different (you can search for a pic that shows the difference).
You *need* to use the corresponding cotters to match the retainers. I'm sure they will fail otherwise.
Quick Reply: DIY Valve retainer replacement with head in place
