Dyno Runs
Old Jul 16, 2005 | 02:06 PM
Hamiy's Avatar
Default Dyno Runs
so I just ran my car on the dyno today. Used mustang awd dyno
Max Power: 190 @ 8500
Pax Torque 127.5 @ 6750
Pretty dissapointing considering I have a test pipe, cat back and cai. I should be dynoing higher #s stock. I don't think I lost any power with the mods though. I think the low #s are from the heat (around 100 degrees) and from the fact its on a mustang dyno.
On that run there must have been a glitch cause my AFR shot up to 20.9
Hopefully with some afr tuning I will be able to pull in some better #s.
I will post up the charts a little later when I can scan them.
Old Jul 16, 2005 | 02:26 PM
Verist's Avatar
Well Mustang dyno are notorious for lower numbers, and it was hot.
Old Jul 16, 2005 | 02:54 PM
Scorpion's Avatar
Add about 10% for dynojet, and 20% for dynopak numbers.
Old Jul 16, 2005 | 03:02 PM
YellowS2kPwr's Avatar
I recently dynoed Stock @ 204hp 138tq on a Dynojet 92 Degrees
Old Jul 16, 2005 | 03:09 PM
Hamiy's Avatar
Well, if the 10% thing is true I am happy. hehe
Old Jul 16, 2005 | 03:11 PM
jyeung528's Avatar
how much does it cost to dyno, and where can i dyno?
Old Jul 16, 2005 | 03:21 PM
Hamiy's Avatar
Any shop that has one in your area. Check your local forums.
I did this on a dyno day (Thanks Gruppe-S) and it was a good price of $50
Old Jul 16, 2005 | 05:37 PM
marknconnie's Avatar
i was there also. my # where nice and low . time was 3:51 and max hp # was 178.5. at 8500 max tq# was 120.8 at 6750. i didnt get get af 02 reading. it was really hot also. i have aem v2, t1r test pipe, veilside exhaust.. there were 2 other n/a s2000 at the time. a stock 01 and another 02 w/vafc basicly stock too. the all have pretty much the same #s i got too.
hamily: when where you there?
Old Jul 16, 2005 | 05:42 PM
Hamiy's Avatar
i was there right at 12 or so. do you know what the stock s2ks ran? Sounds like I dynod pretty high compared to most.
I left at 2 or so I think. I was in the berlina if yo saw me leaving
Old Jul 16, 2005 | 08:31 PM
shivers's Avatar
Why doesn't anybody post the actual dyno plots and a/f ratios? Peak numbers don't mean anything, it's the deltas and area under the curve that matter.
Mustang and Dynodynamics dynos place a load on the car to simulate the conditions you would see on the road. This is why the numbers you get are lower than a DynoJet. You can't really compare numbers across different brands of dynos just because of the way they operate and the output power.
From the numbers you provided, a rough calculation would give you 218-222 whp and 146-148wtq. That's good in my book.
