Engine nº question
I bought my very much fun to drive AP1 S2000 in UK, but the car was first registered in Japan, then imported to UK. I wonder whether my engine spec is the Japanese or the European one. Main reason, knowing the compression ratio, 11,7 or 11. Engine nº is F20C100xxxx.
See if your engine has 2 knock sensors, IIRC that's another way to see if its a JDM F20.
As far as I know only the F20C2 used in Europe. :hello: |
Er ... thanks, but how do knock sensors look like? ;)
They look like the word "search" :p
Plenty of pics of them around here. (lots of broken ones after a clutch change... followed by pic of new ones & part numbers to replace them ;) ) :tipwink: |
Touché.
:p ;) |
Tonicu, are you wondering if it's a JDM S2000, or just a JDM motor in a UK/Euro chassis?
You can easily check for a JDM chassis since they have a different VIN system. That is, instead of something like JHMAP1148YT000814 (my car's VIN, pictured below), if my car were JDM it would just be numbered as AP1-1000814 (see other example below). Non-JDM VIN stamp on firewall: https://cimg4.ibsrv.net/gimg/www.s2k...4c7a2d88a3.jpg JDM VIN stamp on firewall: https://cimg2.ibsrv.net/gimg/www.s2k...6dc5dd6c11.jpg https://cimg3.ibsrv.net/gimg/www.s2k...070cc96e81.jpg Some JDM cars might also have a VIN plate on the front brace over the radiator: https://cimg1.ibsrv.net/gimg/www.s2k...4847e12c40.jpg Not sure if the engine number itself indicates whether it's a JDM or world-market F20C. (As I recall my engine number is F20C-10008xx, same format as above JDM number...but it might be F20C1-10008xx, which would make sense.) Edit: Car's not with me right now, but I just found an old photo of my motor and the engine number is in fact F20C1-10008xx. So your engine number does appear to be for a JDM motor. |
Thanks for your reply and for the pics, 2hoos. My car chasis nº looks like the one that appears on your 3rd picture.
The plate shown in your last one - identical to mine but for the numbers - doesnt's clarify much, as I still don't know whether my engine runs on 11,7 or 11/1 compression ratio, and have 250 or 240PS. |
From what you've described, your engine is the JDM version with 11.7:1 compression, rated at 250PS. Enjoy it -- but use the highest-octane fuel you can find. :thumbup:
I'll have a word then with a colleague at the nearby airfield, see if he can find some BP avgas 80 aviation fuel. ;)
