Engine Smokes
MY 2000, 127K total miles. Engine seems to run too rich. Black sooty film accumulates on rear of car and puffs smoke on acceleration. Back story: Engine was replaced ~10K miles ago (reason is a different story). Replacement engine — could find only 1 in the US with left side drive — had 45K miles with apparent ill treatment. Replacement needed new oil pan seal, water pump, etc. Warranted for 1 yr for internal engine issues — which did not appear, other than the black smoke. The engine is 1 mod newer than replaced engine. My guess is there was some electronic timing adjustment between the mods which leads me to believe a timing adjustment may be necessary. Honda service has no solution within their service options. Am considering engine overhaul, but not sure what we are going after at this point. Any suggestions?
An engine overall will not address black smoke, which means its running rich. You'd spend a lot of money, and most likely reduce engine life, not extend it. These engines are notoriously difficult to rebuild. Most shops experience will work against them here.
The reason the engine is smoking is external, not internal. Don't throw rogue fixes at it in desperation. If I understood, new engine is from a different year car? What year car, what year motor? Which parts off old motor did you reuse? Ecu? Throttle body? Etc? |
Agree with post above. Most likely an external component, not the engine itself, unless there is a substantial amount of oil burn/usage like 1Q ever 500 miles give or take for reference and its creating some fouling. If oil usage is within general common 1 Quart per 1000-3000 miles your good. Good enough. Look elsewhere.
You running a cat delete? Any cel? upstream 02 sensor may be getting tired. TPS may be off calibration map sensor maint items, such as spark plug condition, coil packs, air filter. Just a couple things off the top of my head. |
Very good perspectives. External? This is interesting. Plus overall good advice. Thank you.
Replacement engine is MY2000 like the chassis. I cannot lay my hands on the purchase detail, but I do recall that the engine was a rev level higher than the replaced engine. I have always considered there could have been a software rev with whatever was rev'd in the engine. Honda did all the work -- bless their souls as it was a challenge. Almost everything external on the "new" engine was replaced with better condition equipment from the old engine including coils and water pump. Not sure which fuel intake systems were used. Oil usage is up (or down) to ~500 miles/qt which is about double what I experienced with the old engine. FYI, the old engine failed with a very difficult to detect occasional misfire. Many hours of testing revealed a slight oval shape in the #3 piston wall at the bottom of the stroke. Honda had apparently not seen it before. I will have Honda check the items you list. (I am not savy enough to decipher your script) Again, thank you! |
Originally Posted by MadCityS2K
(Post 24598042)
