Extreme oil consume, 5 liter every 7500km - Page 3 - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Notices
Old 01-06-2019, 05:22 AM
  #21
flanders's Avatar
Do a compression check, that will most likely show the reason on your high oil consumption.
There is no way a faulty PCV or some small gasket is the problem.
flanders is online now
Old 01-06-2019, 06:10 AM
  #22
Chuck S's Avatar
Excessive crankcase pressure forces oil out several places. A new PCV is cheap and worth changing.
Spending hundreds or thousands of dollars/euros on an engine rebuild is an option, of course, put adding a quart/liter every 1000 miles or kilometers is inexpensive. Even "exotic" 10W-30 multi-grades are less than US$8/qt in 5qt bottles. $40 extra every year is all it costs if you're going thru 5 quarts in that time. Note 5W-40 is an approved oil and a bit thicker at operating temperatures so that is worth trying as well.
-- Chuck
Chuck S is offline
Old 01-06-2019, 06:45 AM
  #23
zeroptzero's Avatar
Originally Posted by Filigranas View Post
One member suggested to change this screws. Since lasth month, mines do leak.
Check this out:
I can see at least three oil leaks in this one picture, so start by repairing the leaks with the new gasket kit.
Have you ever checked your spark plugs ? If the motor is consuming 5 litres of oil through the combustion chamber check the plugs as they should be black or oil soaked, it will give you an indication of what's going on. You may also need new valve seals, try to do a compression check and leakdown test in the future.
Avoid the oil consumption treatments as all they do is thicken up the oil, you are better off running thicker oil compared to using an oil thickener additive. You may have frozen piston rings that are being affected by combustion deposits/varnish. A mild oil treatment may help free up piston rings if that is part of the issue - something like auto-rx , check out auto-rx.com for info on their products.
Check your coolant for any oil deposits in case you have a head gasket leak, check the coolant overflow tank for deposits and the radiator fluid.
Try a conventional 40 weight motor oil and change it more often, and see if there is any change in oil consumption compared to the synthetics you've been running, or just try a different brand of oil.
zeroptzero is offline
Old 01-06-2019, 08:25 AM
  #24
Originally Posted by Scigheras View Post
If you read carefully, that service letter mentions only up to 1 liter per 1600 km, in the case those 1600k's were driven during constant high-rpm (racing?) conditions. That seems pretty reasonable to me, as opposed to 1 liter per 1000 km in normal/street driving conditions.
Not saying this will be your problem 100%, but probably you have, like many AP1's, bad piston rings and/or ovalized cylinder bores, resulting in bad oil consumption. In that case you will have to rebuild or replace the engine .
I hope to dot have to rebuild the engine, fingers crossed!
I am waiting for a date with the mechanic, this week I hope.
-- Chuck
I use Motul, in fact bought a full carton of 4 boxes, 20 litters for 100 euros, 25 euros each. What I will consume in 2 years, 15.000 km, two oil changes. Of course adding a extra can is inexpensive, but I am afraid the engine can broke in the future as this going worse or the catalisator
Radiator is brand new, I got an accident and was replaced, will check the sparks since I got to do a compresion test, but as I was saying, since I bought this car with only 37.000 km with 4 years had a lot of oil consume.
thanks all!
Filigranas is offline
Old 01-06-2019, 08:27 AM
  #25
thanks all!
Edit:
Some mechanichs without seeing the car says might be valve stem seals,
Quotted from 1500 to even 4000 euros!
In case was it, what might have been the cause of it´s degrading and how much is a fair price and price for the Honda OEM pieces to replace?
Old 01-06-2019, 08:31 AM
  #26
Where is the EDIT icon? I can´t find it.
There are this threads on a Spanish forum about valve stem seals
Retenes de valvulas; se rajan? - S2000 - Club HondaSpirit
Cambio de retenes y copelas de las válvulas - S2000 - Club HondaSpirit
Old 01-06-2019, 08:37 AM
  #27
nubbel's Avatar
You are driving yourself crazy with all these extensive and therefore expensive POTENTIAL FIXES...
Just start small, do the easy and quick things first
In case it doesn't get rid of your problem you can still invest in further diagnostics/repairs.
As mentioned many times before, fix your obvious oil leaks and replace any other gaskets on the valve cover along with a new AP1 S2000 PCV valve - the Acura one pictured above does not fit your AP1 valve cover.
GENUINE HONDA PCV VALVE S2000 99-03 CR-V 97-01 - https://goo.gl/Qoczb7
Then get a compression tester off of Amazon, no need to spend more than €30 to €40 for one - the numbers might not be accurate, but what you are looking for is CONSISTENCY across YOUR pistons and spending more money is not necessary for that.
While doing that, take a look at your spark plugs, if they are black and covered in soot you might be running rich or it might be a sign of oil getting into the combustion chamber.
https://imgur.com/a/12Rvr - These are mine after 12.000km, I know it's not a lot but might give you an idea what to look for.
However, there are many other threads going into detail on "how to read spark plugs".
nubbel is offline
The Following User Says Thank You to nubbel For This Useful Post:
Filigranas (01-06-2019)
Old 01-07-2019, 11:08 AM
  #28
Being quotted this from Cox Honda UK
Hello,
Thanks for your message. See quotation below for parts:
Old 01-07-2019, 12:54 PM
  #29
TDC Oring = #10 in image
Part # 91333-PCX-003
Oil Filler Gasket #6
​15613-PC6-000
Oil Dip Stick with O Rings #7
​15650-PCX-006​​​​​​
Cam Idle Gear O-Ring #23
91301-PCX-003
TCT Outer Oring #16, but might as well replace 14 and 15 too
#16 14514-PCX-005
#15 14513-PCX-005
#14 14512-PCX-005
TCT Peep hole Crush Washer #11
15302-PE0-300
@Filigranas
Deckoz is online now
The Following User Says Thank You to Deckoz For This Useful Post:
Filigranas (01-07-2019)
Old 01-07-2019, 02:04 PM
  #30
nubbel's Avatar
This is still the wrong PCV valve for your car
Get the black angled one
Oil Dip Stick(cant order orings separate) – On quotation below
If you want to save a few bucks you can buy the dip stick o-rings separately instead of the whole dip stick.
I've used 6,0mm x 2,5mm (inner diameter x thickness) o-rings made of NBR (Nitril-Butadien-Rubber = oil and heat resistant. If you want to go even higher quality you can use green HNBR o-rings - comparable to OEMs).
Hmm since you are already pretty invested in overhauling your engine... Are you still running your stock AP1 valve retainers?
If you do not plan on replacing them, at least, when the valve cover comes off, make sure to take a real good look at them and make sure they are still fine... for now
nubbel is offline
Quick Reply: Extreme oil consume, 5 liter every 7500km
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
