Flywheel modying/uprated version
Old Jun 1, 2004 | 04:13 AM
foz01's Avatar
Default Flywheel modying/uprated version
Has anyone machined and lightened the standard S2000's flywheel?
If so have you recorded what you did to it and was it worthwhile?
I see toda do a lightened version, is this a bespoke manufactured part or a modified standard honda one?
the cars a track only one so not bothered about any disadvantages etc
cheers
foz
Old Jun 1, 2004 | 05:04 AM
Sideways's Avatar
I am not aware of anyone lightening a factory unit. The current consensus is at 9000 rpm you don't want a weakened factory unit. Toda, Comptech and several others make a lighter chrome moly steel unit that will hold up to the high rpm without problems. IMHO, avoid aluminum with any bonded friction surface or rivits.
Old Jun 1, 2004 | 07:59 AM
slipstream444's Avatar
Agree w/ Sideways ...
The Toda is the lighter than the Comptech, but the Comptech can be resurfaced, while the Toda cannot. I have used both and had a problem with the Toda(FW)/Mugen (pressure plate) combo (slipped). This is a popular setup and I'm the only one to have a problem to date (that I'm aware of). I have the Comptech/ACT setup now and no problems yet. Use the stock disk unless you are going crazy in your application. Everyone I've talked with has stated this.
LeonGalt
Jun 12, 2006 01:04 AM
blackfx35
Jun 25, 2005 07:09 AM
alexchou
May 3, 2004 10:12 AM
spesrf25
Apr 7, 2004 05:29 PM
YoungS2K
May 2, 2002 06:41 AM
