front right higher after rolling fenders
I didnt know i could adjust the hight of the fender roller while i was rolling the right front fender so i used a scissor jack to push all the control arms and junk down so the fender roller would clear. Then i found outhow to adjust the roller and did the left side. Somehow i caused the front right to sit about an inch higher. Im on coilovers and messured fender to floor and bottom of lip on both sides and its off. I dont see anything bent on that side and am hoping somebody can shed some ligt on my issue
its the actual car itself. I don't know if its possible to stretch out the coilover and f@#k it up (since I scissor jacked all the components down) or if its something else that's messed up
Site Moderator
You probably did the reverse of preloading the suspension. Loosen the bolts for the coilover and then preload the suspension and torque all the bolts again.
