Ghost issue with starting. PLEASE HELP
Hello! I am having a very difficult starting issue that I have not been able to track down. To start this has been happening for about 2 years I believe, owned for 4. I am also a master toyota mechanic and still it is kicking my butt.
It is an intermediate starting issue. Every once in a while under no specific circumstances, 1 outa 10 times I would guess, I get a starter click. Starter was replaced about a year ago and have bench tested recently with no issues, got good power to starter and signal wire is attached correctly. Good batt voltage and was replaced about a year ago as well. No voltage drop to starter. All easily well visible grounds are good. All fuses are good. Car will also always start just may take 100+ starter clicks. S2000 starters are non contact starters I believe so I wouldn’t think it’s the starter. Took push button off and don’t see any corrosion or any issues behind dash right now. I also do not have a good wiring diagram besides the all data one and need to invest or get sent a good Honda one. Clutch pedal grommets are still there. Battery terminals are new but no voltage drop. 115k miles. Running out of ideas. Are they any S2000 genius’s that can shoot some more ideas or send any starting wiring diagrams my way!!!
Question. Do you actually have that full 12.6v with no drop at starter, WHEN ISSUE IS OCCURRING?
I can imagine you troubleshooting this and measuring voltage at starter as someone is engaging starter, but guessing that was probably when working, not when issue happening.
But when getting only 9v out of ignition switch, what is voltage at battery?
I'm betting its also low there, issue being intermittently bad battery or bad cable.
It is unusual for battery to be intermittent, but not unheard of. Internal short that comes and goes. Basically one of battery cells shorts and its voltage is missing.
If it were ignition switch, relay wouldn't click. Power to starter doesn't go through ignition switch. It just makes relay click, and starter power goes through relay.
So if battery were 12v, but ign switch was only allowing 9v, you'd never hear relay clicking, as there wouldn't be enough juice to energize it.
