Grease for Axle nut?
Might be a stupid question but... I am redoing my axle nut tomorrow and the directions say to grease the face of the nut.. does this require any kind of special grease? or just whatever i have?
Thanks! |
Anyone?
nothing special :thumbup:
The idea is to allow the nut to slide while you tighten it. Alex grease will do just fine.
Molycote or simular.
The idea is to not let the applied torque to be used to slide the face of the nut over the hub but to press the hub, the inner race of the wheel bearing and the axle together. http://home.tiscali.nl/onlinestorage...le%20Click.JPG Normal grease is better than nothing. A good EP compound, like Molycote, is better than normal grease. Its worth it to remove the axle from the hub and clean & grease (Molycote) the splines too. That is more work (remove lower ball joint, etc.) but IMO worth it as you're about 99% sure the problem (axle click) really goes away. To get the final 1% put a light coat of liquid gasket or other silicone glue on the red circle of the outer CV just before putting it all back together. http://home.tiscali.nl/onlinestorage...k%20-%20v2.jpg :hello: |
ummm good advice. i need a ball join remover now.
waste of time just take out the bolt and add grease. :D lazy people :p
oh yeah i used a multi purpose semi-synthetic grease |
spitfire,
i believe anti-seize was used on my splines...is this fine? |
Dow Corning #111 is the grease specified by Honda in their Service Bulletin.
http://home.tiscali.nl/onlinestorage/Never%20Seez.jpg
:thumbup: Any anti friction coating will do. In simple terms, anti-friction coatings can be thought of as lubricating paints. They typically contain a solid lubricant and a binder dispersed in solvent carrier. The coating forms a dry lubricating film to help prevent corrosion and is aesthetically pleasing. Anti-friction coatings are ideal for dusty environments or for inaccessible areas that need long-term lubrication. Dow Corning 111 Valve Lubricant and Sealant can be used as a lubricant for rubber and plastic O-rings, water softener and faucet valves, valve stems for potable water, aircraft vacuum systems, electronic and ignition systems, among others. It can be used as a sealant in applications such as vacuum and pressure systems, equipment subject to washing and harsh environments, electrical service entrances and underground connections, and transformer gaskets and equipment enclosures. I don't think so :tipwink: |
| All times are GMT -8. The time now is 11:56 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
