Yup, mine failed the same way. Previous owner installed the crappy exedy so called oem (its not oem), which is famous for this spring failure.
No need to show us a photo, we've all seen it before. Glad you got it fixed! |
Originally Posted by jflies
(Post 24345369)
Probably nobody cares but I thought I'd give an update in case anyone else ever has this problem. .
I’ve kinda got the same symptoms. The box shifts very smooth if I revmatch, if I don’t then sometimes it feels like I have no synchro’s at all. I think that the problems get worse when the gearbox warms up. At first it gets more difficult to shift into the higher gears, then the lower gears start acting up too. If I want to downshift into second gear I need to get the revs up really high, and when they match it shifts quite smoothly. If I’m not doing that it feels like hitting a wall. the car has been sitting for a year, so maybe I should grease some things. I think it still has the original clutch in it, the car has 150k km on it. Basically the car shifts very smooth when revs are matched. If not it feels like I have no synchros at all. Clutch seems to work perfectly, I can rev and shift easily when standing still, the car doesn’t move |
Originally Posted by Asserti
(Post 24633718)
Clutch seems to work perfectly, I can rev and shift easily when standing still, the car doesn't move
So you could easily have enough drag to cause grinding but no where near enough to make car move. Your symptoms are consistent with clutch drag, and I suspect that is indeed your issue. If fluid isn't clean and clear, do a full bleed using gravity bleed method, making certain reservoir never runs dry during process. Next adjust clutch rod. If there is still symptoms, try adjusting height of clutch pedal to raise height for more total pedal throw. If this step makes a significant improvement, you have an internal issue with clutch. Something like rusted splines, guide is not smooth, insufficient or wrong lube, or a crappy Exedy so called oem/ebay disk that is starting to drop a spring. Only fix is to drop trans and address, and at that point it just makes sense to do a full clutch job. Drive with higher pedal height to ease further damage to trans while you plan for clutch job. |
Originally Posted by Car Analogy
(Post 24633767)
Not a very valid test. The amount of clutch drag required to move a nearly 3k lb object that is at rest (objects at rest tend to stay at rest) is way more than would be required to keep several pounds of rotating mass inside trans to remain rotating at engine speed (objects in motion tend to stay in motion).
So you could easily have enough drag to cause grinding but no where near enough to make car move. Your symptoms are consistent with clutch drag, and I suspect that is indeed your issue. If fluid isn't clean and clear, do a full bleed using gravity bleed method, making certain reservoir never runs dry during process. Next adjust clutch rod. If there is still symptoms, try adjusting height of clutch pedal to raise height for more total pedal throw. If this step makes a significant improvement, you have an internal issue with clutch. Something like rusted splines, guide is not smooth, insufficient or wrong lube, or a crappy Exedy so called oem/ebay disk that is starting to drop a spring. Only fix is to drop trans and address, and at that point it just makes sense to do a full clutch job. Drive with higher pedal height to ease further damage to trans while you plan for clutch job. There is new MTF3 in the gearbox too, so when it shifts smoothly, it's really smooth. I've stupidly been driving the car the last few days for a few 100kms, and know I notice extra noise at constant speeds :(. The car also sometimes wants to move with the clutch in, so maybe it's just the master clutch cilinder on the way out.. |
I doubt its the mc. They rarely really go bad to the point of allowing drag (if tbey are leaking, usually just flushing woth new fluid resolves it. Though sometimes if fluid is dirty enough, for long enough, they can develop leaks onto carpet that persist even after fluid is flushed.)
I wouldn't be surprised if its a crappy aftermarket clutch disk that is starting to drop a spring. Often the spring moves around and sometimes drags and sometimes doesn't. Or sometimes drags more or less. It slowly gets worse until one day spring drops completely and clutch locks up solid. |
(Post 24635034)
...and while this is a rare failure, it shows they do sometimes fail. But even if you have such a failure, you'd know something wasn't right as you'd be losing fluid with no obvious wet area.
^^ yep mine is the first I have personally heard of actually failing. It was odd af first. I noticed it was not right, found the fluid was low, topped it off so I could finish the event and it was perfectly fine for a bit when I checked, then lost a good amount again in the afternoon. That is why I suspect it was mainly occurring after multipe runs (it was a practice event, so probably 30-50 runs in a day) when it would get hot. So likely a seal going but not totally gone yet. And I was pleasantly surprised that I did not find hydraulic fluid soaked carpet when I got home :)
I kinda have the same problem with my clutch i have an AP1 '01 at first i was annoyed by the so called "clutch buzzed" i went in and bought a OEM/ACT clutch combo w/ streetlite flywheel. After breaking in the clutch around 1.5k miles with them, i noticed that every time i shift starting from 2nd gear to the 6th gear i always hear that grinding noise, to tell you ive been driving manual for over 6yrs now and i know for a fact too its not my driving. Every time i drive my Civic Si the same way i drive my s2k i dont hear any grinding or what ever noise coming in from the transmission or clutch. At first i thought i would go away but recently this shit just gets annoying and whats weird is that when tried to up shift from 2nd to 3rd and 3rd to 4th so on an so fort, just like how your start from first gear that you have to slowly release the clutch and give gas it wont make that noise. I already have the master cylinder replace, transmission fluid done and new clutch kit. Im hoping regreasing the clutch fork, replacing the slave cylinder and adjusting the engagement point of the clutch will help.
Who did the clutch replacement? Did they properly grease everything per the manual? Did they use Honda Urea grease? Was the clutch bearing guide also replaced when clutch was done?
If the answer to any of these questions is no, or even if its I'm not 101% sure, then that is likely your problem. Clutch isn't disengaging smoothly, and its dragging slightly. Just enough to interfere with syncros operation. |
