Its difficult to speculate. Most of us don't have experience with the long term effects of running a clutch with a bent pp finger.
You won't know until you remove trans and inspect. Thats free if diy. I would start there. |
Can we get Billman in here? I feel like he would be the one most knowledgeable of this.
Originally Posted by Car Analogy
(Post 24356453)
Originally Posted by Belkin623
(Post 24356561)
I'm just trying to get any solid information before I spend a whole day or get stuck for 2 weeks again without a car and screwing everyone around me. No, I won't know but at least I'll have a better idea of how important it is to do asap or in 3 months.
Originally Posted by riceball777
(Post 24356620)
to me this sounds very important and I would. It drive the car any more for the risk if you doing more damage to the transmission or engine. If you wait a few months and continue to drive the car best case scenario is you don't do any addition damage but worst case scenario is the nose gets worst and you damage the transmission to the point you need a new one. Or worse the bent clutch some how warps your crankshaft and you need a new engine. If I was you I would throw the car on jack stands and pull the transmission tonight.
Last time I saw this problem, the starter was loose, and the flywheel was sawing through the nose of the starter.
Be sure it's tight. |
Originally Posted by Billman250
(Post 24356871)
Be sure it's tight. Do you mean the intense grinding after 5.3k could be caused by the starter being loose or only the light grinding? |
(Post 24356871)
Be sure it's tight. How likely is it that I would need to replace the whole transmission rather than just the clutch and P/P? |
