Help: Which Battery should I get - Page 5 - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > General Interest > S2000 Under The Hood
Reload this Page >
Notices
Old 02-06-2019, 08:44 AM
  #41
Are you sure you don't have an overcharging issue that is damaging the batteries? Maybe its the car, not the batteries...
Car Analogy is offline
Old 02-07-2019, 03:22 AM
  #42
I've had an interstate in mine for 2 years and it spends a lot of time hooked up to a battery tender. No leaking here.
By the way, a regular 51 that's available everywhere fits just fine. Not sure why anyone would say you have to "make it fit". You just have to bend the negative terminal cable a little bit. It's not under tension or anything (at least not on my car).
92gli is online now
Old 02-07-2019, 04:48 AM
  #43
Slowcrash_101's Avatar
Originally Posted by Chuck S View Post
Local AutoZone slipped a new battery into my car last summer. It was in stock there. Nothing exotic. All the battery really does is start the car and mine wouldn't. Battery test is less than 5 minutes.
-- Chuck
The battery also works as a capacitor and helps keep signal noise from the alternator down. If the battery is weak or not plugged it, the alternator has to work overtime to keep system voltage. This can rob as much as 3hp from the engine, which may not seem like much. But when you take off from a light in normal driving the car is probably making 10hp, so sapping 3 will be noticable.
Slowcrash_101 is offline
midnightsunset
08-31-2015 10:40 AM
s2kcanuck
04-22-2015 07:44 AM
Jamie_Murray
05-10-2009 04:55 PM
ProV1
11-16-2006 05:47 PM
Jaysom
06-17-2002 08:54 PM
Quick Reply: Help: Which Battery should I get
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
